Ignition Cylinder
Old Sep 16, 2006 | 02:36 PM
Sleeper's Avatar
Ignition Cylinder
Someone (aka - Tweeker) broke into my wife's Runner last night and screwed with not only the driver lock to get in but the ignition. It turns to start but will not engage. I'm purchasing a new cylinder vrom AutoZone tomorrow. Is there a write-up on replacing the cylinder? I searched but did not find. Any help would be appreciated.
ANdy
Old Sep 16, 2006 | 03:57 PM
slacker's Avatar
there is a brass pin in the cyl .
to remove the cyl , you have to first remove the plastic covers .
put the key in , if you can ... and turn to "accessory" . Look on the top for a hole . with a hair pin or paperclip (what ever) put it into the hole and push the brass bin down to release the cyl . and pull it out .
If you can turn the key to "accessory" just take a small punch , put it into the hole , and give er' a wack ... you'll have to "smash" the brass pin ... and pull out the cyl ... easy .
hope that helps .
Old Sep 16, 2006 | 10:15 PM
Sleeper's Avatar
Originally Posted by slacker
"...hope that helps .
Thanks brother - Definately helps.
ANyone else please feel free to chime in..........
Old Sep 16, 2006 | 10:18 PM
Elton's Avatar
here you go http://www.4x4wire.com/toyota/mainte...nition_switch/
Old Sep 17, 2006 | 07:26 AM
Sleeper's Avatar
Originally Posted by Elton
There we go - thanks a bunch.
80Truck
Oct 12, 2025 07:25 PM
Sleaker
Aug 26, 2020 06:03 AM
TDonkey
Jul 26, 2015 10:14 AM
94whiterunner
Jul 12, 2015 07:15 PM
cars-guy
Jul 11, 2015 07:51 PM
