92 22re tmiming issues
Old Sep 21, 2006 | 08:35 AM
toyotamanxxx's Avatar
i have a 92 4 runner...with 22-re...
with my distributor turned all the way clock wise ,im about 8-10 deg. BTDC....
.i spun the dist. one tooth and that put me right on TDC...but now the distributor is all the way counter clock wise now....that is just backwards from the start point......
i cant seem to get this right... also from front to back what are the cylinder #'s..?..... 3-2-4-1...?????? thanks for your help
Old Sep 21, 2006 | 09:36 AM
ZUK's Avatar
ZUK
I bet your chain slipped a tooth.
Old Sep 21, 2006 | 10:33 AM
PirateFins's Avatar
Try following this procedure http://personal.utulsa.edu/~nathan-b.../5distribu.pdf always works for me.
Old Sep 21, 2006 | 10:36 AM
could it be that i just need to clock the pulg wires....it ran find untill a friend and i put in the brand new dist. ..
Old Sep 21, 2006 | 10:57 AM
Yota82's Avatar
This is what I do: Pull #1 plug and turn engine over manually and stick your finger over #1 spark plug hole and wait for the compression stroke. When on compression stroke you should feel the pressure try to go past your finger. Get it to TDC in #1. The distributer rotor should be facing at #1 which is about 10:00 (if you compare it to a wall clock). If it is not pull the dist out and find the right tooth to make the rotor face #1. Have a buddy crank it and move the dist clockwise and counter clockwise slowly until it starts and then you can put a timing light on it and set it. The cyl. # from front to back are 1-2-3-4. The firing order is 1-3-4-2. The cap should tell you where 1-2-3-4 are.
bigjstang
Jun 2, 2025 03:56 PM
MO transplant
Apr 23, 2023 11:58 AM
mskalmus
May 28, 2017 07:51 AM
montanatruck
Feb 26, 2017 07:07 AM
PlayAwhile
Jul 20, 2015 11:36 AM
