ABS help needed...
Old Sep 14, 2006 | 06:55 AM
s t A t i c's Avatar
ABS help needed...
one year ago when i added my Sdori BJ spacers and ome springs and shocks my rear abs was malfunctioning. when you would apply the brake the pedal would "pulsate" continuosly until released. my question is why. i understand that there is a valve above the rear axle that has a link to the axle that controls the fluid flow to the rear brakes. after the lift i fabbed a 2 inch piece to accomodate for the change in the valve angle. however, it continued to pulsate, so i removed the abs fuse and the problem went away. No Abs at the time wasn't a big deal. However I now have a house in the mountains(steep inclines, and declines) and the abs would certainly help. my brakes have locked on me twice in the last two months up there.
any ideas on how to fix this?
anyoneelse had the same problem?
as always all help is greatly appreciated!
Old Sep 14, 2006 | 07:21 AM
Robinhood150's Avatar
check your codes (clear them first).
Old Sep 14, 2006 | 08:13 AM
theyre all clear it hasn;t thrown one. just one for my speed sensor because my speedo is out
JimiJams
Sep 28, 2015 06:14 PM
BimmerSage
Sep 17, 2015 11:48 PM
BimmerSage
New York
Sep 17, 2015 05:21 PM
matt1833
Sep 16, 2015 07:11 AM
zz_denis
Sep 6, 2015 03:43 PM
