Clutches
Old Sep 20, 2006 | 09:56 AM
92foreruner's Avatar
Clutches
I have a dilemma here I have a 3.0 4runner after having done a search on cluthces on the site I have even more questions about which clutch I should use. Right now I have a Centerforce dual Friction but it seems to need replacing more often than a stock clutch. I tow a 14' alummnium fish boat and camping gear every other weekend as well as off road from easy to mod trails. What do you guys recommend for my truck. I like the way the Centerforce works but the Warranty sucks. The reason all this came about less than 9 months after having a rebuild done on my tranny is it's damn hard to put it in first when sitting still and grinds going into reverse after waiting a few seconds to put it in gear. The shops says it's a clutch problem
Old Sep 23, 2006 | 11:26 AM
Elton's Avatar
i would go with a www.marlincrawler.com ceramic one
Old Sep 23, 2006 | 11:32 AM
farmerj's Avatar
Look at your shifter ball. Is the seat any good? Mine was giving me a hard time in 1st and I put a new ball in and it worked fine.
Old Sep 23, 2006 | 05:45 PM
Dave Mooney's Avatar
Shift ball
Just put in a new Napa Clutch. Made in China wouldn't you know. Seems to work fine. The pressure plate was made in China also but the steel for it came out of Germany. Where do you get a shift ball? Dealer item only or wrecking yard? Mine is a little stiff going into first as well. Clutch works fine.
Old Sep 23, 2006 | 07:42 PM
farmerj's Avatar
Check with Evan at Northridge toyota. If you have an 88, you need to replace the whole plate. All other years can get by with one from enginebuilder off the forum here.
Old Sep 23, 2006 | 07:48 PM
yota_krazy's Avatar
i would check your clutch master and slave cylinder for leakage before you blame the clutch, if it doesnt release all of the way then it will grind. Good luck
Old Sep 23, 2006 | 08:16 PM
86SR522REEFI's Avatar
Get the marlin crawler. its awesome
Old Sep 23, 2006 | 08:31 PM
tc's Avatar
tc
Wait - a shop told you that the clutch made it difficult to shift into certain gears (not all)? Time to find a new shop...
X3 for shift seat bushing
kawazx636
Oct 6, 2021 03:03 PM
primordialbeast117
Dec 19, 2015 12:23 PM
smilen724
13
Nov 8, 2015 04:11 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
