knock sensor question
Old Sep 23, 2006 | 08:46 AM
xentrino's Avatar
I'm putting a remanned 3VZE in a 94 4runner. I'm planning on reusing the knock sensor but can't find torque specs on it. When I took it off the bad engine it was tight as hell but once it broke free I could remove it by hand. Also, how necessary is it to replace the knock sensor wire?
Thanks for your help.
Old Sep 23, 2006 | 09:48 AM
BC Rider's Avatar
Page EM-194 of my fsm says "install and torque the know sensor" but there is no spec for the torque anywhere. The conventional wisdom is tighten it up so it does not rattle around at all, but don't tighten it up too much. Not much help - is it. My best guess is less than 20 ftlbs. I used 10 and was happy with the snugness.
Knock Sensor wire - about $15 - and is usually what goes on these. Toyota techs are apparently told replace it whenever they remove the intake manifold. Mine went after a HG replacement. I would recommend 100% to replace the wire.
Old Sep 23, 2006 | 11:19 AM
Elton's Avatar
replace the wire now its a pita after its all put to gother
Old Sep 23, 2006 | 12:38 PM
xentrino's Avatar
Thanks for the info and the quick response!
tj884Rdlx
Aug 28, 2015 12:04 PM
nonstop
Jul 24, 2015 06:29 PM
keithporter83
Jul 18, 2015 12:37 PM
88yodabasket
Jul 13, 2015 01:32 PM
smiley52
Jul 11, 2015 05:16 AM
