PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 [209] 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. motor swap, wont start
  2. Selling the ol' Land Cruiser
  3. water pump gasket
  4. Is Anybody Running
  5. 1995 4runner a.d.d. transfer case
  6. paint stripper..?
  7. Motor Help with 1994 4runner
  8. Alternator or Battery?
  9. locking tailgate handle
  10. 3.0 in Camry, same as in 4Runner?
  11. the 1988 P/U im looking at
  12. Yes...Its another lift question
  13. Need fuel injector help !!
  14. squeal at start up
  15. Help me with this weber
  16. 4runner was parcked for 4 years!!!
  17. Catalytic Converter Theft - BEWARE!
  18. Fabtech
  19. Help with E-brake indicator light
  20. ---ignition. key--- button lock bypass ---(how to)
  21. 33s or 35s.
  22. Please help diagnose... engine going DOWNHILL!!
  23. clutch adj please help!!!!!!!
  24. egr removal
  25. Can't remove CV axle
  26. Head Unit in a truck...
  27. new header/exhaust = crappy MPG or other cause?
  28. 4th gear (o/d) weakest link?
  29. V6 Timing Question...
  30. K&N FIPK for the 3.0L, pro's & con's wanted
  31. Need Help
  32. Knock Sensor
  33. Bodywork
  34. Got My Shackles!!!!!!!!!!!!
  35. Dies when put in reverse
  36. Hi Lift Mounting
  37. brake problem, need help
  38. Will 31's fit on stock 89 Pickup?
  39. Fuel line issues
  40. New Coolant Leak Problem - Can I replace this??
  41. taking out 22re and putting a new one in
  42. 1990 4x4 2 door t4r?
  43. Ordering wheels next week... back spacing?
  44. rear glass question
  45. does anyone remember????
  46. 93 pickup clutch problem!!
  47. Huge engine problem
  48. what is this part called?
  49. 1990 V6 Mass air flow flow part #?
  50. Add-A-Leaf question
  51. Bench Seat
  52. Broken Ring Gear?
  53. Find out about recalls.
  54. 88 3.0 fuel pump not working
  55. 1993 3.0 v6 cylinder pressure
  56. Bad Shackle Angle?
  57. Auto Trans Shifter is Loose..
  58. 92 - 3.0 - A little grumpy when shifting...
  59. 86 carb intake manifold 22r
  60. i found
  61. clutch pedal bracket broken AGAIN!! is this a common thing??
  62. Wind whistle?
  63. 94 Pickup Rotor Question
  64. Time for a tune-up
  65. MPG Reality
  66. High Output Alternator's for 2nd Gen 4runner's
  67. power dis box under dash????
  68. ...and it came back worse?
  69. Starter Problem
  70. questions about 3.4 swap - what did it cost you? (and more)
  71. Need help finding a vacuum line that feeds all 6 cylinders in my '95 4Runner
  72. 1991 4-Runner...Mind of its own!
  73. dimmer switch help 2 kinds!
  74. 1995 knock sensor HELP!!!
  75. A plethora of things.
  76. Codes 12 and 14?
  77. Rod Knock!!! what should i do?
  78. Biggest Speaker in Doors
  79. 5Sp Vs Auto
  80. Old man Emu
  81. dana 44 high steer Inverted T
  82. transfer case gears
  83. Bought an 88
  84. 87 22re cranks for awhile
  85. 22re compression levels
  86. Think I found my coolant leak - please advise.
  87. Couple of Questions....
  88. Where do I stand?
  89. 95 3.0 issues
  90. 3vze engine cleanup
  91. 86-91 front bumper or 92-95
  92. cut FJ80 coils?
  93. Changing Pistons!
  94. 86 22r running strange
  95. 22R electric fuel pump conversion
  96. Fuel Leak ... need help quick
  97. where is the fill plug on my tranny?
  98. Cant find part need ASAP
  99. Flipping a Car.,
  100. Timing Troubleshooting - LOST !!!!
  101. 22re auto trans bog.
  102. Torsion Bars
  103. U-joint hitting gas tank skidplate
  104. dana 44 set up?????
  105. need a little help
  106. 1997 wheels on 2nd gen
  107. Throttle bolt
  108. 3.0 3vze direct manifold vacuum line location?
  109. coil suspension
  110. purging coolant of air
  111. Header fitment
  112. What is this 4runner worth?
  113. mpg on 3slow
  114. Lift & Tires Question
  115. Brake Master Cylinder
  116. clutch problem
  117. gurgling,bubbling sound AFM
  118. 5spd swap wiring Q for 3.0L V6
  119. axle question
  120. sand blast my frame
  121. 88 4runner v-6
  122. Installing a new clutch
  123. SR5 Cluster question (manual cluster fitting in an auto rig)
  124. Downey header noise
  125. Another 3VZE Head gasket hypothesis
  126. Rear flex pics
  127. What years 5speed tranny fits this 94?
  128. Spark plugs
  129. Synthetic Oil Question??
  130. Well LOOKY what I found...
  131. just replaced clutch...problem
  132. New Interior Mods
  133. Zuk Mod Installed.......w/o any modifications
  134. Easy Question for the Right "GEAR" Head. Diff Ratio Related
  135. late 80s S10 camper shell?
  136. engine problems
  137. steering leak with smoke?!
  138. 3vze timing belt help
  139. Snorkel hardware
  140. Brake fluid gushing onto my floor
  141. hella 200mm question
  142. ARB CKMA12 Install Question.
  143. Damn remote start...whew
  144. Transmission "exchange"
  145. $800 4 a 884runner what to look for?
  146. Wheel stand (ifs sucks)
  147. check engine light help
  148. how can I fix this broken box?
  149. Can any TURBO guy tell me the part Number of your MAF?
  150. Truck is eating coolant, but to where?
  151. Master cyc. ?!?!?
  152. Brown Interior Paint
  153. Toyota Idiot Book (maintenance) - Upload Available
  154. How do check engine codes?
  155. PIC: New Grant Steering Wheel
  156. New Dash (Control panel)
  157. oil cooler removed? 3vze
  158. HELP!! 22RE poor Fuel ecomony in new motor!!
  159. idling goes up and down
  160. Metal ID needed for Front IFS steering arms on Knuckle
  161. Another clutch question...
  162. An old article I found with some Dyno #'s
  163. Best place to buy spark plug wires?
  164. ball joint spacers need HELP!!!!!
  165. vibrations
  166. which head gasket????
  167. Heres another starter NOVEL!!!!!!
  168. 86 wish/dream list
  169. A shimmy, and I'm about to give up.
  170. Balljoint Replacement
  171. horrific sounds
  172. Hard Top Paint
  173. Checking for worn clutch
  174. 94 4runner high idle
  175. Poor running...plugs?
  176. TG 4" leafs w/IFS lift- what length shackles
  177. Oil Pressure Question
  178. head gasket question on 3.0
  179. Anyone running a twin stick?
  180. Clutch replacement advice 93 Pickup
  181. A/C pic request
  182. A/c
  183. 22re question
  184. will 1st gen control arms fit second gen
  185. Crispy Critter Any good???
  186. tire pic request...
  187. Herculined bumpers
  188. Clutch master cylinder
  189. 3.0 V6 New Head, Best source?
  190. 22RE Piston Cleaning options?
  191. 1986 4Runner Lift Question..
  192. optima red-top discharge question
  193. 3.0L 3VZE initial idle speed (rpm) on starting
  194. 3.0 L 3VZE @ 15 degrees btdc. timing
  195. Where should I set asking price on 87' Runner?
  196. Grinding Noise at Highway speeds
  197. Need to replace muffler and tail pipe
  198. New Shoes
  199. APR head stud help 3.0 3vze
  200. 1994 4runner 4.3 swap help
  201. grill clips?
  202. 22re engine swap complications! help
  203. 1987 Pickup electrical problem
  204. Any alternative MAF's usable for 22re?
  205. help!!! starter,battery???wtf
  206. Brake problem
  207. front end swap.. need help
  208. 3VZ-E pinging
  209. Will 63 in chevies work w/BJ spacers
  210. 10-12,000 mi trans fluid life??
  211. horn stuck on
  212. what tranny do i have?
  213. egr valve
  214. Vibrations when braking!
  215. Cold Weather, Now Poor Fuel Econemy...
  216. small electrical fire now blowing 80A alt fuse
  217. Marlin Crawler bumper pictures?
  218. talkin about balljoint spacers
  219. Parts From eBay Stores
  220. taillight covers
  221. Sliding Rear Window, 88 Pickup, Hard to Open/Close
  222. 22RE ignition timing
  223. New Here, New Truck
  224. locked out!! asian style!!
  225. HC fail-reading 907, allowed 151
  226. a good year for 22r pickup?????
  227. Going to go look at an '86 runner
  228. coolent leak "please help"
  229. Metal Dinging Sound coming from engine?
  230. 88 Truck A-Pillar gauge pod
  231. Should I replace the rear main seal??
  232. Flywheel orientation
  233. Whats This Part???
  234. Stock 89 4runner, suspension
  235. Make or buy e-locker wire kit?
  236. 3VZE Opening up the exhaust w/o a lot of expense
  237. front driveshaft removal
  238. 89 4runner v6AT over drive issues- advice? you too?
  239. oil sending unit question on 3.0
  240. headgasket...
  241. best way to clean a gas tank
  242. Houston, we have a problem.....
  243. Help with a copy of a diagram
  244. Paint Question
  245. Anyone out there have an SR5 Standard Cab 3rd Gen?
  246. Right after startup, clunk then died
  247. Tire fitment Questions
  248. How much does a rebuilt title effect value?
  249. Should it be changed? timing chain
  250. Low power to 3000rpm?
