Synthetic Oil Question??
Old Jan 12, 2008 | 03:04 PM
anthonyallred's Avatar
Wondering about synthetic oil in an older motor. The engine has 300,000KM on it and The head gasket, rear main engine seal was done when engine swapped, and the oil pan has been re sealed. Would it be safe to switch to synthetic??? I head the only concern is that your old seals will start pissing synthetic if it has had regular its whole life?? Are there any other major seals I should worry about or should I go ahead and use syn?? Thanks
Old Jan 12, 2008 | 03:10 PM
YotaFun's Avatar
All I can say is search dude.
Its a wonderful button at the top of the bar there.
This topic has been discussed over and over on this forum.
Old Jan 12, 2008 | 03:15 PM
PCE91V64x4's Avatar
You can buy high-mileage synthetic as well as regular synthetic. Your call. Everyone has an opinion, but my next oil change will be with high mileage synthetic and Mobil 1 filter.
Old Jan 15, 2008 | 02:14 AM
TNRabbit's Avatar
there are two opposing schools of argument on this. Some have had bad luck with switching, but I've switched with SEVERAL high mileage vehicles and never had a problem. If the seals are questionable, you could induce leaks because the synthetic WILL loosen old sludge, etc., possibly opening up a path for oil to flow out.
Old Jan 15, 2008 | 05:18 AM
mtrdrms's Avatar
Ive never had a problem with the switch. High mileage, low mileage it doesnt matter. People used to scared of switching back to petroleum based oils from sythetic because of the swelling agents in the synthetic but no longer. I would run synthetic in my lawn mower if I had a good one.
Andy
Old Jan 15, 2008 | 05:49 AM
Flash319's Avatar
I am with Andy. I have never had a problem and Do run synthetic in my lawnmower.
Old Jan 15, 2008 | 06:17 AM
TNRabbit's Avatar
me,too:
Old Jan 15, 2008 | 06:24 AM
Squeebs's Avatar
Synthetic rules.
Old Jan 15, 2008 | 12:30 PM
surf4runner's Avatar
if it leaks, switch back...
bigjstang
Jun 2, 2025 03:56 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
thefishguy77
Jul 30, 2015 10:59 AM
88yodabasket
Jul 13, 2015 01:32 PM
Coreyr384
Jul 10, 2015 11:13 AM
