33s or 35s.
Old Jan 17, 2008 | 12:49 AM
88-surf's Avatar
33s or 35s.
hey guys im not sure if this has been brout up or not.
what do i need to do to fit 33s and 35s?? better to go 35s over the 33s?
thanks
Old Jan 17, 2008 | 12:52 AM
aaron's Avatar
thanks
what gearing do you have??
Old Jan 17, 2008 | 02:03 AM
88-surf's Avatar
4.3. i no ill be going to 4.8s or 5.1s or somthing like that.
.but what do i need to do to the surf to fit the 35''?
thanks
Old Jan 17, 2008 | 02:27 AM
85TurboRunner's Avatar
I have a 4" lift and I run 35's. they rub when the wheels are turned and I'm flexed out, it might not be as bad with IFS though since they don't flex much.
Old Jan 17, 2008 | 05:30 AM
MIKEMOKAS's Avatar
to run 33's
4in suspension or 3in body
4.88's
to run 35's
4in suspension
2in or 3in body
5.13's
also think about wheel backspacing if youre worried about zero rubbs.
might as well lock it while your in there too.
good luck.
Old Jan 17, 2008 | 05:52 AM
EWAYota's Avatar
they don't make 5.13 gears for toyota's. you'd need to run 5.29's for 35's....IF you have a 5spd.
5spd or Auto? If you have an auto, I'd stick with 33's and run 5.29's or possibly 5.71's.
Old Jan 17, 2008 | 07:18 AM
AxleIke's Avatar
Wait, are you saying this has been brought up before? No...Really?
33's depend on how wide you want to go. 33x10.50 fits with zero lift.
12.50 does not.
35's require either a sawzal, or a 4in lift. I prefer the sawzal method.
Old Jan 17, 2008 | 09:18 AM
MIKEMOKAS's Avatar
im sorry, youre right, i made a mistake. ive got 5.13's on my mind because some kid near me has his mind set on running 5.13's in a 4.3 sas'ed zr2 s10 and wants to run 38's. over-geared in my opinion.
12.50 does not.
33x10.5's clear on stock wheels, correct?
whats stock wheel width and backspacing?
Old Jan 17, 2008 | 09:47 AM
Lysmachia's Avatar
I have an auto, 35's and 5.71 gearing. Looks like you have a 22re manual? So prolly 4.88's if you do 33's or go for 5.71 (just as strong at 5.29) if you go 35's
Old Jan 17, 2008 | 10:14 AM
tc's Avatar
tc
http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
33x10.50 on the stock rims is the most cost effective thing you can do for these trucks.
If you leave the IFS alone, it will perform well for you and hold together very well.
Start adding balljoint spacers (for lift) or a bracket lift and 'wheel it hard and you're gonna have issues with the steering.
Old Jan 17, 2008 | 11:32 AM
isharj's Avatar
I put 33x10.5's Radial TSL's on my 90 model a few months and they work great. I've been very happy with them.
Had to flatten the seam at the back of the wheel well on the fronts but other than that they don't rub at all.
Old Jan 17, 2008 | 11:46 AM
88-surf's Avatar
I want 33x12.5 or 35x12.5.
Ive got 2.4td with 5speed.
Wen i go to get these wheels certified i will be doing the lift aswell so i don't have to come back and certify the lift later on,
What should i do just go with the 35s or 33s. ill be getting a bj spacer and bl. what size should i get them? in mm plz
Old Jan 17, 2008 | 12:35 PM
tc's Avatar
tc
Why are you dead set on the wider tires? Doesn't really bring anything positive to the scenario ... just negatives.
http://www.expeditionswest.com/resea...tion_rev1.html
Certified? What are the modification laws in NZ like?
Old Jan 17, 2008 | 12:39 PM
Tofer's Avatar
Sponsor
nope, as far as i know this topic has never been covered on YT. thank you.
thanks
you dont need any lift. just use your super awesome fab skills and a sawzall
Old Jan 17, 2008 | 12:53 PM
88-surf's Avatar
There gay really. anything bigger then 33'' off rubber on your car needs to be certed unles they come out with them.
any sorta lift has to be certed or just about any sorta lift.
and because 33x10.5s or 35x10.5s will just look silly like my one does atm
Old Jan 17, 2008 | 01:32 PM
Lysmachia's Avatar
Yeah come-on tc..... Only you like the look of pizza cutters....
Old Jan 17, 2008 | 02:18 PM
AxleIke's Avatar
Yeah, they are silly.
What ISN'T silly is breaking steering and CVs every single trail run. That is SOOO awesome. In fact, I may go back to fat tires SPECIFICALLY so I can break every weekend.
Old Jan 17, 2008 | 02:33 PM
88-surf's Avatar
don't have rocks and e like you do axle all we have is mud and hils and the odd ditch that we play in. well thats all i do anyways.
Old Jan 17, 2008 | 05:21 PM
olharleyman's Avatar
Originally Posted by MIKEMOKAS
to run 33's
4.88's
to run 35's
4in suspension
2in or 3in body
5.13's
good luck.
I run 35's with just a 4" suspention lift no need for the body lift just a small bit of trimming and 5.29's in my 5speed 3.75 backspaceing on the rims
live4soccer7
May 11, 2016 06:52 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
Higbee89
Aug 27, 2015 06:52 AM
Cabell
Jul 24, 2015 12:14 PM
Tacoma750
14
Feb 23, 2005 12:59 PM
