how can I fix this broken box?
Old Jan 11, 2008 | 08:12 PM
taikowaza's Avatar
What would be the best way for me to reattach this broken attachment point?
I am not sure if washers would hold due to the ripped plastic. Any ideas appreciated! Thanks!
Attached Thumbnails how can I fix this broken box?-crack1yt.jpg   how can I fix this broken box?-crack2yt.jpg   how can I fix this broken box?-crack3yt.jpg
Old Jan 11, 2008 | 08:15 PM
neoworm0's Avatar
I don't think I'd waste my time. Go to the wreckers and get another one.
Old Jan 11, 2008 | 08:17 PM
jason191918's Avatar
If you look closely you can see that mine is zip tied on. That's one way to do it.
Or you could just buy/acquire a new one.
Jason
Old Jan 11, 2008 | 08:22 PM
toytech76's Avatar
If you know anyone with a plastic welder you can try that
Old Jan 11, 2008 | 08:35 PM
CJM's Avatar
CJM
Plastic welder or epoxy it very good. If you epoxy yopu could use a bolt that sticks out and a wing nut.
Old Jan 11, 2008 | 08:44 PM
A soldering iron and some plastic would work too. Any of these should work just fine.
Old Jan 11, 2008 | 08:48 PM
drew303's Avatar
Jb Weld It!!!!
Old Jan 11, 2008 | 08:57 PM
anotherjeff's Avatar
If is is ABS plastic, ABS glue/solvent (from the plumbing dept) will mend it. It should be labeled as to the type of plastic. The grill is ABS, for example.
Old Jan 11, 2008 | 09:00 PM
jct61765's Avatar
Junk yard, it cant be that expensive.
Old Jan 12, 2008 | 07:57 AM
burnscore1's Avatar
Drill a hole and zip tie that sumbtch
Old Jan 12, 2008 | 08:13 AM
Dublin's Avatar
Bypass it, mines been out for about 3 years.
Old Jan 12, 2008 | 08:18 AM
1990Runner's Avatar
^ x2 ISR mod will take care of that. coming soon to mine
Old Jan 12, 2008 | 09:49 AM
taikowaza's Avatar
bypassing that box
thanks for all the replies, I have lots of ideas now. I had not even heard of plastic welders before, I thought it was a joke at first...then I checked online and realized it was serious!! thanks for telling me about that.
I am curious about the bypassing option...what is the name and purpose of this box anyways, and if I bypass it is there any disadvantage or positive effect?
I have the ISR mod and the FIPK.
Old Jan 12, 2008 | 10:08 AM
Dublin's Avatar
It's just a resonator box, the sound of your engine will change a little bit.
Old Jan 12, 2008 | 10:40 AM
old4runner's Avatar
wrecking yard would probably best but you could possibly jb weld a washer in there
Old Jan 12, 2008 | 07:26 PM
Steveh29's Avatar
If there's enough plastic 'meat' left you can drop a hot washer on there and let it melt into the plastic. I've used that trick a time or two and it's worked fine on other stuff.
Old Jan 12, 2008 | 08:17 PM
taikowaza's Avatar
there are so many good ideas in here. I love that idea of melting a hot washer into the plastic. also the idea of bypassing it entirely. the solution I finally followed was (I quote) Burnstar's solution to: "Drill a hole and zip tie that sumbtch"
thanks guys that worked great, if it happens again I will bypass it entirely or get a new one
thanks again for all the tips!!!!!!!! I learned a lot from this thread!!!!!
cgilley
Jul 25, 2015 10:55 PM
HookahRoo
Jul 20, 2015 07:06 PM
rushw
Jul 18, 2015 01:46 PM
jon.r
Jul 11, 2015 03:34 PM
crashburnoveride
Jul 10, 2015 06:39 AM
