Time for a tune-up
Old Jan 15, 2008 | 07:29 AM
yotaman90's Avatar
Time for a tune-up
I know how to do it, but I don' know what the best components to use are. I've heard different opinions about Bosch, NGK, and Denso, but everybody has their favorites. The engine that I want to do the tune-up on is a 3VZ-E which needs the full job (cap, rotor, plugs, and wires) and I want to use only quality parts. I need your opinions! I can't decide!
Old Jan 15, 2008 | 07:34 AM
MMA_Alex's Avatar
NGK OR DENSO!
Do a search!
Old Jan 15, 2008 | 07:35 AM
fast7mtoys's Avatar
bosch is the devil!!!!
use only toyota wires, ngk or denso plugs
the toyota wires last alot longer than any others i have ever used
Old Jan 15, 2008 | 07:37 AM
yotaman90's Avatar
I have Bosch +2 spark plugs in my '87 and they do just fine (don't foul as often, engine burns oil). Not to contradict you though
Old Jan 15, 2008 | 07:44 AM
TNRabbit's Avatar
www.sparkplugs.com
Denso or NGK plugs & wires.
Old Jan 15, 2008 | 07:55 AM
yotaman90's Avatar
How much are toyota wires (don't exactly have a local dealer to ask)? And also, how much longer do iridium plugs last then platinum?
Old Jan 15, 2008 | 08:20 AM
yotaman90's Avatar
I think I'll try Denso, seems like the best. What about a cap and rotor?
Old Jan 15, 2008 | 08:35 AM
fast7mtoys's Avatar
well remember that denso builds most of toyotas electrical parts so if you can find denso wires you will be just fine, if the truck burns oil i wouldnt worry about a high dollar plug just a basic denso or ngk would work, as for the cap and rotor denso or ngk, you can run a cheaper cap and rotor but it might not last as long, i guess all im saying is keep it toyota (denso) and it will last alot longer remember toyota takes everyones ideas and perfects them!
Old Jan 15, 2008 | 08:39 AM
headgasket's Avatar
Stock Toyota Wire Set w/clips from Northridge Toyota
Hey for what it's worth. Order the stock set delivered to your door at 25% off of list which is $86 retail from Toyota. So a set should be about $62.00 total.
Call 1-818-734-5600 ask for Carrie or Richard.
They will ship free to your doorstep just mention evan Nichols(Parts Mgr.'s name and his offer to yota techies like yourself)
I went with the NGK blue wires for $32.36 but pd. my own shipping so something like $43.
The NGK wires are blue unlike the stock black wires. They do not stay in my Toyota OEM Distributer cap. The stock Denso Wire set has the distributor clips which keep the wires in place. the old ones can be reused if you still have them and then the NGK wires will perform just fine.
We are using the NGK wire set and getting 18 mpg.at freeway speeds. About
the best mpg for a heavy 4 x 4.
Let us know what you go with; most guys so the Toyota wires are no place to skimp.
Old Jan 15, 2008 | 08:55 AM
MMA_Alex's Avatar
I wouldn't replace the plug wires unless they're out of spec (use the tests from the fsm)
the multiple electrode plugs are crap. as soon as it wears a bit it wont fire through both, and they just block the air/fuel mixture from the spark.
I've thought about using the iridiums, but I'm too inpatient to order them, and they're never in stock. maybe some day...
I like to pull the plugs pretty often (its really easy with the 22re) so I can check how the engine is running.
Old Jan 15, 2008 | 09:49 AM
TORTIS's Avatar
NGK plugs..
X2 on ohming the wires.
Old Mar 7, 2008 | 12:17 PM
yotaman90's Avatar
Well, its been two months and I'm finally going to do my tune-up. I decided to go with Denso iridium plugs and wires, but nobody really told me which are a good quality cap and rotor. Thats all I really need to find out before I start my tune-up
Old Mar 7, 2008 | 12:53 PM
904_runner's Avatar
Toyota Cap and rotor!
Old Mar 8, 2008 | 03:26 PM
T4R 4ME's Avatar
2x Toyota cap and rotor.
I'll even make it super easy for you since I have these parts sitting in front of me.
Cap Assy 19101-65040 $15.53/$11.65
Rotor As 19102-70160 $8.20/$6.15
As mentioned above, call Northridge Toyota. Prices above are full retail and Northridge's discounted price. They should have these in stock and be able to get them to you in a few days. Make sure you verify part #s though as they occasionally change.
Old Mar 16, 2008 | 07:01 PM
DJK-West's Avatar
Is that the Northridge Toyota in the Los Angeles county? If so, I am not far away from it at all. I'm in San Fernando.
Old Mar 17, 2008 | 07:18 AM
yotaman90's Avatar
How would I pay for these parts? Money order?
Old Mar 17, 2008 | 07:58 AM
mr_schuster's Avatar
NGK and Denso are my top choices for plugs and Toyota uses both. Has any one ever taken notice that the OEM plugs on the 3.4L (from the factory) had NGK's on one side and Denso's in the other? The heads were cast and assembled in two different plants. I would go OEM on cap/rotor/wires.
Old Mar 18, 2008 | 07:53 PM
T4R 4ME's Avatar
That is them. Don't go out of your way to save a few $$$. They'll ship for free, just give them a call.
Old Mar 18, 2008 | 07:55 PM
T4R 4ME's Avatar
Give them a call and work something out. I've always done CC over the phone. Guess you could do a MO, but that would take a while for them to receive it, cash it, send parts, etc.
Old Mar 18, 2008 | 07:57 PM
DJK-West's Avatar
I work a few blocks away from North Hollywood Toyota, told them about Northridge Toyota's price, they matched their price. I win!!!
