Time for a tune-up
Old Mar 19, 2008 | 07:20 AM
yotaman90's Avatar
Originally Posted by T4R 4ME
Give them a call and work something out. I've always done CC over the phone. Guess you could do a MO, but that would take a while for them to receive it, cash it, send parts, etc.
I'll call when I get a chance, I need to get paid first. Do you think that you could guesstimate as to how long the parts would take to get to NM?
Old Mar 19, 2008 | 07:21 AM
yotaman90's Avatar
Ooo, almost forgot. How much are their OEM wires? Do you know?
Old Mar 26, 2008 | 11:06 AM
Blk97Sr5's Avatar
I'm also about to replace my wires and plugs so I so looked up the specs on the Toyota Field Service Manual for a 5VZ-FE, Here they are:
Recommended Spark Plug: ND (Denso) K16TR11, NGK BKR5EKB-11
Correct electrode gap: 1.1 mm (0.043 in.)
Primary ignition coil resistance: Cold = 0.67 - 1.05 Ohms, Hot = 0.85 - 1.23 Ohms
Secondary ignition coil resistance: Cold = 9.3 - 12.0 kOhms Hot = 11.7 - 18.8 kOhms
The plugs that they recommend are actually quite reasonable (ND $2.31, NGK $4.31 at sparkplugs.com). I don't see any reason to buy the more expensive plugs, unless you have an SC or running custom fuel management software. If those plugs are what Toyota engineers have researched and recommend, I'll take their word for it. As far as the wires go, I agree with what the previous posters have said, as long as they are still within spec, I don't think it is necessary to replace them. There are other goodies I would rather spend my money on.
Hope this helps.
Old Mar 26, 2008 | 11:15 AM
DJK-West's Avatar
I picked up a set of OEM wires, including the wire clips (most of mine are missing), for $95. I have no complaints, fitment is something no non-OEM manufacturers can match. In the 3.0, the engine compartment is very tight. It's scary not to have something to keep your plug wires from touching any hot surfaces. Two of my wires were messed up due to that, one of them literally melted when touching the hot EGR pipe. Made the engine run horribly rough.
Old Mar 29, 2008 | 03:27 PM
  #25
yotaman90's Avatar
Hope this helps.
I want the more expensive plugs because they will last a lot longer then regular plugs, and also I'm lazy and don't like doing tune-ups very often . And thanks but I don't think that those specs would be applicable to my engine, which is a 3VZ-E not a 5VZ-FE
Old Mar 29, 2008 | 03:35 PM
  #26
yotaman90's Avatar
Originally Posted by DJK-West
I picked up a set of OEM wires, including the wire clips (most of mine are missing), for $95. I have no complaints, fitment is something no non-OEM manufacturers can match......
Thanks thats really helpful
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
smiley52
Jul 11, 2015 05:16 AM
