suspension q's
Old Mar 29, 2008 | 07:48 AM
93rustedyota's Avatar
suspension q's
how do u crank the torsion bars to get more hight? and will i be able to clear 33's stock in the rear and with it cranked in front or maybe some lift blocks in the rear i just got a good deal on some 33's on rims so i need to clear them and how bad will it be driving with stock gears and 33's r any of u doing this?
Old Mar 29, 2008 | 08:13 AM
norcalsvx's Avatar
33x12.50's or 33x10.50's the wider ones wont work but the 10.50's will work with a crank and pounding the pinch weld
Old Mar 29, 2008 | 08:44 AM
Brenjen's Avatar
Soak the torsion bar bolts in penetrating oil a few days before you try to move them. The day you are ready to try; clean all the crud off the bolt with a wire brush & coat the bolt down with anti-seize compound above the nut & inside the housing, you can reach a good portion of it through the hole in the side & start turning. It helps if the weight is off the vehicle first but it will turn even without jacking it up.
On mine, the drivers side bolt was stuck to the crescent shaped washer & it turned with it. It popped & screeched as it snapped back in & out of the saddle it's supposed to ride in but I just stayed after it with a 1/2" break over bar & eventually it all worked loose well enough that the washer stopped moving with the bolt & I could turn it with a regular ratchet.
Old Mar 29, 2008 | 03:46 PM
nmtoy's Avatar
Before you adjust your torsion bars read this...
http://toyota.off-road.com/toyota/ar....jsp?id=398514
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
ktm192k
Oct 1, 2015 08:47 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
