coil suspension
Old Jan 13, 2008 | 06:30 PM
wncmtnrunner's Avatar
coil suspension
my 4runner is sagging and i was wondering if i could swap in 2 in coils instead of stock ones what would it look like perform is it pretty easy to swap coils
Old Jan 13, 2008 | 06:43 PM
WCorbett's Avatar
ummm what? youll need a coil compressor tool and longer shocks to compensate for the height and travel.
Old Jan 13, 2008 | 06:56 PM
jfreisner's Avatar
Vehicle info?
It's very simple to do.
If you can fill-up without spilling too much, then you will have great success completing this project!
Old Jan 13, 2008 | 07:04 PM
Would I Need Shocks All Around Or Just The Reaer
Old Jan 13, 2008 | 09:08 PM
Matt16's Avatar
Pretty easy to do. I used Old Man Emu medium duty rear springs- the kind that left about an inch and a half about stock. You don't technically need a spring compressor, but it saves time and work.
Remove the wheels and jack the frame up so that the wheels would clear the ground. Put the jack under the axle to hold it up.
Undo the shocks at the bottom
Disconnect the parking brake cable from the suspension arm (not from the drum)
Undo the sway bar
Undo the brake line from the axle housing (again, not the drum)
Let the axle droop with the jack.
Push, lever of stand on the drum until you can manhandle the old coils out.
use the spring compressors to squash the new springs down enough to fit them back into place making sure to line up the end of the coil with the indent in the pad it sits on.
Put it all back together and don't worry that you truck looks like a cat in heat. The springs will settle until it looks even with the front.
Old springs
New OMEs
Old Jan 13, 2008 | 09:13 PM
RobD's Avatar
Undo the sway bar
I went the same route, installing OME Nitrochargers at the same time. Handles extra weight of the family and our gear on trips just great. Next it's the fronts, new OME torsion bars and Nitrochargers.
Old Jan 13, 2008 | 11:59 PM
Matt16's Avatar
I did the rear shocks at the same time, though I used ES3000s. I am not sure the ES3000s I got were long enough though- they were for stock to 2" lift, but I think they are limiting my travel. I will soon find out.
The rear shocks are a pain, especially on the passenger side. I gave up unbolting from above, thought about grinding from above, saw the brake line runs right by the top nut on the shock stud and gave that idea up too.
The only easy way to remove the rear passenger shock I know of, is to take a grinder and cut away at it from below. It took me about 5 cuts.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
MadMax48
Mar 3, 2020 10:33 AM
choppe777
May 16, 2016 08:00 AM
justdifferentials
Sep 5, 2015 06:52 PM
