- bad vibration while accelerating
- 88 toy weird brake noise
- newb valve clearance question
- How to fix my tailgate?
- Wrong rear end
- Is this supposed to be open??
- New Tps still have a code
- Steering Stabilizer Woes
- 22ret won't idle!
- Antifreeze leak under intake
- Noisy distrubuter
- OME Spring measurements?
- V6-3.0 3VZE Power Steering Pump Run-Dry: Rebuild?
- rtv, locktite, never sieze, ect
- Tell me about your clutch
- 2.2 4Y Weber 32/36 DGV
- MAF Trouble?
- Oil in air filter box help
- Which 60mm TB for my 22re wil plug and play?
- em-4 simple digital systems
- DIY headlight wiring harness upgrade for low $$
- New to the Yota Family
- Front Right Wheel Locked in 4wd
- Look I found my ADD actuator
- transfercase tailshaft bearing?
- Idle hunts - warmed up with brake only
- Extending seat sliders
- How can I tell if my 4runner have ABS?
- air fuel ratio
- 91 Motor Problem :( (head Gasket)
- Igniter wiring help
- Anyone know what this is? Strange Black Box.
- 87 4runner manual trans problem
- oil pressure question
- Need some help with a couple items to repair
- what kind of axles, 4runner 89
- Timing woes
- 89 22re trying to pass smog
- Opinion on my build idea
- takes a while to start when the truck is cold?
- 4Crawler BJ/Rear Coil Spacer’s…The WriteUP
- need quick help - bleeding clutch system
- new member with 86 4runner
- Christmas Break Photoshoot (56K no way)
- 1995 3VZ Temp Sensors Identification (What is it) Game
- ARB Bull Bar with 1" Body Lift
- Anyone use these guys?
- 95 4RNR 3VZE Swap problem.
- Really bad gas mileage. HELP!
- Heater/vent light
- what is this part?
- Few locker and general questions for my 92 4runner
- Tire weight question
- continuisly leaking oil
- Drive Shaft Center Carrier Support Bearing...Affordable replacement
- Update concerning my transmission mount
- Aftermarket or stock rear coils?
- 86 4runner body lift with auto trans
- 3vze sensor question
- bj spacers loosening?
- How do I get to the blower resistor?
- Horrible gas mileage!
- please help! 89 v6 no spark or power at ignitor
- Squeeky belts!!! please read
- high performance cams anybody?
- Roof Light Bar
- Jammed A/C tensioner pulley Q
- 91 22re sputters
- Battery keeps dieing help!
- 1989 P/U Auto questions
- 1994 toyota pickup 3.0 v6 cam issues
- '95 22r-e knocking when cold
- 1st Gen Bumpers on a 2nd Gen...Can it work?
- Engine swap 3vze to 3vze?
- want to install some kill switches on my 91
- part no. inquiry
- 1994 4x4 questions...again.
- 1994 Pickup making a clicking sound while turning in 4x4
- Replacing motor on 1992 V6 4Runner
- fixing damaged wiring connectors
- '92' 4runner 1st time timing belt change
- Replacing engine in 88 4x4, how hard?
- 1st post rear main/trans removal
- trouble with my 22re engine help?
- 3.0 engine swap
- 22R Carburettor - special screw?!? / gasket?
- Replace transmission input shaft bearing
- Upgrading Torsion Bars
- Removing tailgate glass
- How does my block look?
- 22RE sluggish
- How to tighten antenna base to fender?
- 87 toyota clutch problemshttp://images.ibsrv.net/ibsrv/res/src:www.yotatech.com/get/i
- Elocker added, now no rear sway bar......
- 87 -- 22r rebuild -- Disaster with Airfilter butterfly screw!!!
- 3vze problems
- 60's and 44's is running
- I think I killed Rhonda (my 4Runner) *Pics*
- leaking rear diff
- 22re ran out of oil
- 95 toyota 4runner after key off and out...
- ifs front gears to front straight axle
- Check My Diagnosis - Fan Bracket/Belt Q
- 22RE wierd "sputter/gurgle" problem. Help!
- 22RE dead need advice
- Rear gate lock switch, R&R?
- Question regarding alloy rim sizes
- Lift and Tires installed! (Big Pics)
- Oil question
- reunited and it feels so good
- drivability help. stumbling
- spark plug help, w/ PICS
- Real world 3vze highway gas mileage
- Homemade gap guards
- Canvas Camper/Topper?
- Brake upgrade question.
- 88 22RE rebuild, need a wiring and vac line diagram
- Engine surging while stopped.
- Pulling the fuel pump help please
- Painting the Frame and Body of the Pickup (Lots of Pics)
- Herculinered the back of my 4Runner
- 22re swap wont start
- dual shock hoops
- Why does Temperature gauge goes to H even when cold
- Overheating issues!
- Tranny question
- 90 3.0 cruise control won't work
- Removing tar boards
- gurlging sound when heat is on
- Brake Calipers
- Upper Ball Joint Trouble!
- I need help with vacuum line setup- 92' 22RE
- Well...so much for my under 100K truck
- Help diagnose a problem with front suspension on an '86!
- bucket seats
- Best Clutch for DD'ing with 31s?
- for those in sub-zero climate (clutch issue)
- front locker
- 92 3vze surging problems Need help
- 1987 extracab pickup auto tranny sluggish
- 1989 22re Motor Stumble, TPS
- timing belt mistake
- 1st gen 4runner owners. Does this happen to you also?
- 90 sr5 3.0 wont run, fuel pump issues.
- Differential Education
- Overdive cold
- 130amp alternator SHOT...
- R134a conversion fittings...
- Body mount bolt sizes / 1" BL
- Rattle associated with clutch
- 95 4Runner heater not working
- Brake Light won't go off
- No Fuel Again...
- Cold air intake on 3.0 V6
- Stuck Starter---Maybe
- 89 22re wont start
- I'm the lucky winner of needing a new driveshaft prize!
- wont drive in second...uphill
- engine problems
- Name that part...
- How do you remove oil seal of inner front wheel bearing wihtout damaging
- intermittent Smoking
- Tranny shot?
- powerloss
- Transmission problems?
- 4WD won't engage, help? 1992 Pickup 3vz-fe
- Mystery 'miss' on #1 Cyl of 3VZE
- What's going to eventually happen to my whiny transmission?
- #6 blew again...What would you do???
- 22RE loading up
- 94 PU Starting issue
- 1st gen 4rnr rear windows woes
- pic request - electrical connector
- Amsoil Air Filters - gauging interest
- 1990 - 1995 Part Swap
- rebuilt head on carbed 22r
- 2nd gen 4runner back door window problem
- zuk mod, and spring price...
- Throttle body spacer
- Question- Motor swap
- 3VZ no start!?!?
- ifs lift question
- Intercontinental favour anyone?
- advice on heater core
- Spec Question
- 1uzfe
- Double locked IFS with dual cases...
- RPM's drop to 0 and shut off my 4Runner at a stop!!
- Emissions Missions!
- power steering hose - pump to reservoir
- strange misfire
- Fuel lines + pump
- 96 Bucks for a fuel line
- Replacing Ball Joints upper and lower
- Disc Rotors
- 3vze runs terrible under load
- spark plug gap 22re
- Anyone Rockin 5.29's with 31's?
- 86 4runner tranny problems?
- How do you check a tranny and transfer case when buying used?
- 3.4 swap transmission question
- Lots of 22re q's, not many answers in Australia
- Checking out a 22re block
- old truck needs new shocks
- 89-95 with newer factory wheels
- 22 re steel guides and rock oil pump
- 90 5 speed fit into 88 auto runner
- help, gear stuck!
- 92 4runner ISR Mod
- 22R oil pan clearance?
- wildbill's 89 4runner
- just bought it, tire help
- G52 to W56
- not heating up. and a knoick problem
- Clutch sticking to the floor?
- truck wont go into gear while running?
- weird cooling issue
- Anyone Know Who's truck/Bumper this is?
- Inner Fender
- Clutch pedal help
- Odd Cooling Problem
- no heat but good temp?
- Split Second MAF Conversion??
- Idler arm bushings Toyota part number?
- 22R - Need Head now...
- 93 Pickup 22RE Temp Gauge Stays on cold. No Heat. High Idle
- shakes at higher speeds
- 4wd on wet pavement?
- Charging system opinions wanted
- Idle Air Screw and O-Ring Part Number
- Another "my blower don't work" thread
- Difference in T-cases?
- Roof rack and rear wind deflector
- Some engine thoughts - 22re
- please tell me the gauges are the culprit...
- Saggy butt
- Power brake booster gaskets
- Motor Swap from 4th to 3rd
- 1st gen 4runner window rubber
- 22R Ignition Timing
- Another nasty sound from my truck
- what kind of fender flares to use with 37" tires?
- Need some advice on a carb selection
- 93 pickup air flow sensor trouble
- Signs of a faulty clutch for a 1995 Toyota 4Runner?
- Snow Pile Pics
- new 22re Grinding :(
- thermostat issues?
- Exhaust collector nuts
- Temp and fuel sender help!
