shakes at higher speeds
Old Jan 4, 2010 | 08:33 PM
95PhoRunner's Avatar
Hi everyone,
95 4runner is shaking when I get to higher speeds. It shakes and vibrates for a while and then stops. It usually starts at around 45mph and its on and off up until about 65-70mph. My rpms usually don't go higher than about 3000. I can really feel the vibration in the front of the car.
I know i have to replace the idler arm bushing but other then that the susupension looks good based on what the shop guys told me today while they were welding my exhaust on.
Any ideas?
Thanks
Old Jan 4, 2010 | 08:41 PM
abecedarian's Avatar
So you know you have a worn front suspension component but for some reason the vibration you feel in the front end isn't related to that?
Old Jan 4, 2010 | 08:43 PM
myyota's Avatar
Make sure your tires are balanced, and check your wheel bearings.
Old Jan 4, 2010 | 09:00 PM
Abe I just figure there has to be more than just that idler bushing for the amount of shaking. if i'm just driving in town and keeping under 40 there is usually no shaking.
how do i know if the wheel bearings are bad?
Old Jan 4, 2010 | 09:10 PM
You could spend the next few months balancing tires, changing shocks, ball joints, tie-rod ends, wheel bearings, steering dampener, etc. chasing down this vibration only to find out that the part you already knew needed replacing.... need I say more?
the vibration is speed related. the idler arm locates the relay rod. play in the idler arm means play in the relay rod. play in the relay rod means tie-rod ends can move.
I'm guessing the truck doesn't like bumps on the right side?
Old Jan 4, 2010 | 09:16 PM
i'm certain you are right. first yota for me and first car where I'm trying to get in there and wrench. I'm picking up the bushing in a couple of days and swapping it out this weekend. If that bushing fixes it i will dance naked in the streets. Ever since I got this car i've had a lot of problems and I've replaced a lot of things so I am just expecting the worse at this point.
Old Jan 4, 2010 | 09:20 PM
ET's Avatar
ET
go to a tire shop for a balance and rotation. the place i went to told me they couldn't do it because my idler and pitmann arms were too loose and needed replaced. im pretty sure all that ever really needs to be replaced is the pitmann arm but i got "heavy duty" ones to replace both of them.
Old Jan 4, 2010 | 09:23 PM
redneckgirl's Avatar
jack up your truck on one side, grab your wheel at 12 and 6 and push in and kinda move it around twards you. if it has any play in it and moves then you have some issues goin on. also feel for any vibrations while your moving it.
Old Jan 4, 2010 | 10:04 PM
paynemw's Avatar
i noticed a huge improvement in the stability of my ride when i installed OME heavies and stiffs specially around the 60-70 range when previous to the lift it shook like a mofo at the same speeds...
Old Jan 5, 2010 | 03:05 AM
I'll start with the idler arm bushings and report back asap. Thanks everyone for your input.
Old Feb 21, 2011 | 02:03 PM
4x4jeffyota's Avatar
did you ever fix the problem?
stoneboy91
Apr 5, 2016 05:17 PM
lectric80
Aug 11, 2015 12:02 AM
Cbr954ryder
Jul 25, 2015 06:32 PM
jake_v
Jul 22, 2015 03:17 PM
wilbertd
Jul 6, 2015 07:39 AM
