Jammed A/C tensioner pulley Q
Old Jan 11, 2010 | 04:56 PM
Wulf's Avatar
I'm 1/2 way through the fan bracket replacement project. The timing belt looks good (thankfully). But I'm having a heck of a time with the tension pulley for the A/C belt. Specifically it will not slid up in its track and loosten. I finally got sick of being stuck and cut the belt off, but I'm going to need to get it free to finish the project.
Is there some trick. I backed the adjustment bolt all the way out. Beat on it. Tried levering it against the bracket. My next step will be to put a jack under it and see if that gets it loose. Figure I'd ask here to see if I'm missing an obvious trick.
Old Jan 11, 2010 | 05:01 PM
betelnut's Avatar
Maybe a dum question, but did you loosen the nut on the idler pulley?
Old Jan 11, 2010 | 05:07 PM
Wulf's Avatar
Doh! Where's the smashing yourself in the face with a hammer Smilie?
You're saying the bold through the center of the pulley locks it to the adjustment track? I figure it just bolted the pull on and the adjustment bolt held the travel position. That might explain it.
I swear I loose my mind as soon as I lie down on a creeper.
Old Jan 12, 2010 | 08:09 AM
betelnut's Avatar
Heh, yep, that should be the problem. I only knew this because my FIAT had the same mechanism. Glad your problem's solved.
Old Jul 7, 2014 | 03:35 PM
KidSheleen's Avatar
Waking up a 4 1/2 year old post. I wish I read this thread before I twisted the head off the A/C Idler Pulley Lock Bolt.
The FSM is very vague about this. They could have added one more small sentence:
a) Loosen A/C Idler Pulley Bolt
It took two jam nuts and a hard tubing line wrench to back out what was left of the the old bolt.
I guess there are at least two of us who just ASSuMEd what was correct. Go figure.
Dale Johnston
11
Oct 31, 2015 10:22 PM
Badlander
Oct 10, 2015 08:05 PM
moparbay
Oct 6, 2015 09:24 AM
Obmi
Oct 4, 2015 11:30 AM
Odin
Sep 26, 2015 06:56 PM
