Won't keep running
Old Jan 3, 2010 | 02:29 PM
Jerbou71's Avatar
Won't keep running
I just bought a 1992 4runner and it worked great. I just got done putting a new stereo in it and now when I start it it start good then shuts down. On my 2001 silverado it did this when I changed out the steering colum. It was the computer I had it tow it to the dealer to have the computer reset. I didn't remove any thing with the colum in this truck. Any help I need to move the 4runner and I can't.
Old Jan 3, 2010 | 02:50 PM
Junkers88's Avatar
Did you disconnect the battery while messing with the stereo? If not then you may have caused an issue with the ECU (heck anything is possible on these rigs).
My advice is to either pull the ECU fuse for about 4 minutes or disconnect the battery for the same amount of time. The ECU might reset.
Old Jan 3, 2010 | 02:55 PM
Jerbou71's Avatar
No I didn't disconted the batt when I did the stereo becase the stereo has a plug so I unpluged the old stereo and wired the new stereo to the plug and then pluged it back in.
Jerbou71's Avatar
Were is the ECM in this truck at?
Old Jan 3, 2010 | 03:55 PM
Jerbou71's Avatar
Well I disconected the batt for about 15 min. And hooked it back up and nothing it starts up and runs for a second and then shuts down. How do I find out if there is a code? On my olds I can use a paper clip and it will tell me what codes are coming up.
Old Jan 3, 2010 | 05:18 PM
Jerbou71's Avatar
come on guys any other ideas. the truck is in my garage and i need it out to put my classic car back in.
Old Jan 4, 2010 | 06:25 AM
Jerbou71's Avatar
No one else he's had this happen?
Old Jan 4, 2010 | 06:37 AM
Junkers88's Avatar
I should have asked this first. What engine is in there?
You can jumper the T and E1 connections (I think, you might want to search) and get the codes. I also did some reading on "start then stop" problems (through a search of this site) and came up with a couple of things.
1) The relay to the fuel pump has gone out. You can verify this using the "paper clip mod" although I don't know how to do so. (search)
2) There is a leak in the intake plumbing. I read this from a guy that had a V6 and there is a clamp that came loose letting in more air than the engine wanted so the ECU would cut the fuel. He could get it to run for a little while if he stood on the skinny pedal.
Can you keep yours running by using the gas pedal or does it still die?
Old Jan 4, 2010 | 08:07 AM
Jerbou71's Avatar
Ok, guys I know I am new to this site, but I do usally know my way around under the hood. But I feel really stupid today. I am leaving this message for anybody that has this problum. The problum was when I took the air cleaner lid off and put the new filter in, there is another tube underneth the big tube going to the throtle body, and the clamp was loss so it fell off. So you could say I had a LITTLE air leak. Lol thanks for all the help guys. Keep your eyes up and your wheels down.
Old Jan 4, 2010 | 09:16 AM
thedanned's Avatar
Alright then...
sandyota
Feb 4, 2021 11:16 AM
Doug4320
Mar 24, 2018 10:11 PM
Tykiller1994
Aug 10, 2015 07:49 PM
hangtown88toy
Jul 10, 2015 02:33 PM
raiderhawks00
Jul 8, 2015 06:23 PM
