1995 3VZ Temp Sensors Identification (What is it) Game
Old Jan 12, 2010 | 11:43 AM
clocklaw's Avatar
Hey guys, I was wondering if there are any gurus that could help me figure out what a couple of these things are. I had a couple of plug in connections that were broken on the truck and then glued back on by the PO and I was trying to figure out what they were and if I could get a replacement connection. In the picture, there are 4 sensors. I know the one on the right of the picture is the Cold Start Injector Time Switch and the one on on the far left is the Engine Coolant Temp Sensor. The one that remains a mystery is the left rear with 1 wire coming from it....green with a white stripe. I need a replacement connection for the cold start injector time switch and the one with the green wire....after this I think I will have been able to clean up all of the pecker tracks from the PO.
Thanks for any help!
Old Jan 13, 2010 | 02:30 AM
buckz6319's Avatar
the short one with the single flat blade is for the temperature gauge .....the one that your referring to would be in the manual..I can't remember what that one is for
Old Jan 13, 2010 | 06:26 AM
betelnut's Avatar
Go to toyotapartszone.com, or look at your EPC.
Go to the electrical section.
Diagram 13, for the EFI, has three of those bits, and two are labeled.
HTH
Old Jan 13, 2010 | 06:58 AM
clocklaw's Avatar
I have been unable to find that one.....I will keep searching.
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
bighaydn
Aug 4, 2015 07:17 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
bryan34w
Jul 6, 2015 05:53 PM
