gurlging sound when heat is on
Old Jan 9, 2010 | 10:52 AM
4runner4life93's Avatar
Question gurlging sound when heat is on
93 4runner v6 when I turn the heat on and hit the gas there is a gurlging sound that gets louder as more gas i put to it. I can switch it so my ac it does not make the sound anymore. Please help.I cant really explain the sound =(
Sorry.
Old Jan 9, 2010 | 10:54 AM
keep in mind im only 15 i dont know that much about cars.
So you might have to explain it a little bit.
Old Jan 9, 2010 | 11:04 AM
sb5walker's Avatar
The end of the first post may help-
https://www.yotatech.com/forums/f116...nt-faq-192781/
Just elevate the front of the vehicle so the top of the radiator is above all heater hoses, slide heater control all the way to hot, make sure rad is cool then pull the cap off the rad and run the motor. Once the engine reaches operating temp, hold rpms around 2000-2500 for a while to get the coolant circulating well. Refill radiator with antifreeze or a 50/50 antifreeze/distilled water mix as the air works its way out. (Make sure you use the same type antifreeze as what's in there.) Then recap the rad and you should be good.
Old Jan 9, 2010 | 11:15 AM
Thanks alot.Its 15 degres here so i will try that when warms up.Keep ideas coming
Old Jan 9, 2010 | 11:43 AM
shaeff's Avatar
It's air in the system, plain and simple. If doing what sb5 doesn't work, look for pinholes in any cooling hoses. Even a pin hole will cause those symptoms. After that, it gets into a different ball park, but I won't mention that yet.
Old Jan 9, 2010 | 12:52 PM
thanks wold air in system cause the antifreze to come out in puddles sometimes its happend 2 or 3 times
Old Jan 9, 2010 | 12:54 PM
**would air
if air in system wouldnt this gurgle when ac is on too
Old Jan 9, 2010 | 01:02 PM
sb5walker's Avatar
Where did the A/F come out? Did the vehicle overheat at the time? Possible blown head gasket. Compression test would give you more info.
Old Jan 9, 2010 | 01:27 PM
shaeff's Avatar
No, that's caused by leaks, or a BHG.
No, because when the the HVAC knob is pushed to the left (cool air), it closes the heater valve so little to no coolant circulates through the heater core. That's where you're hearing the air/gurgling from- the 'core.
That's what I didn't want to mention before, the possibility of a BHG.
Old Jan 13, 2010 | 07:56 AM
My truck has had a blown head gasket.
Old Jan 13, 2010 | 09:17 AM
sb5walker's Avatar
Sucks.
Anthony Lee Mathis
Sep 15, 2015 07:22 AM
LotOMiles
Sep 14, 2015 11:45 PM
Kreedy1
Sep 8, 2015 06:33 PM
larrys93pickup
Sep 6, 2015 06:37 AM
--Oz--
Sep 6, 2015 01:06 AM
