Upper Ball Joint Trouble!
Old Jan 9, 2010 | 10:06 AM
bio6040's Avatar
Angry Upper Ball Joint Trouble!
Need any advice I can get about a very stuck upper ball joint on an 86 runner. I think I was giving very bad advice and now I'm in a bad situation! Any help would be great!!
Old Jan 9, 2010 | 10:11 AM
dark_fairytales's Avatar
go to autozone and pick up a new set then replace them.
Old Jan 9, 2010 | 10:26 AM
bio6040's Avatar
Have new ball joints. The problem is the ball joint was stuck and someone said to cut the joint off and drill out the tread. Did not work! Bad Advice!! Now the treaded stud is stuck in the knuckle and will not come out with any puller or ball hammer trick. Any advice?
Old Jan 9, 2010 | 01:45 PM
The_Jerbel's Avatar
If gear puller tools won't work and hammers won't work, then I would get a bigger drill bit and drill the entire stud out of the knuckle.
Old Jan 9, 2010 | 02:03 PM
raydouble's Avatar
Pickle fork......and a BFH.
Old Jan 9, 2010 | 02:19 PM
iamsuperbleeder's Avatar
holy crap, that's like a half inch stud have fun with that drilling...
yeah why wouldn't you just use the proper tool to begin with? just wondering
but at any rate, the hole in the knuckle is tapered, so even drilling out the threads is not going to get all of it out, just fyi
Old Jan 9, 2010 | 02:34 PM
ryanday's Avatar
heat and a big hammer
Old Jan 9, 2010 | 03:32 PM
bio6040's Avatar
Thanks for the advice. So far PB Blaster and 15 lb. hammer has got it to move a little bit. But it still is not out all the way.
Old Jan 9, 2010 | 06:03 PM
raydouble's Avatar
Leave the nut on the balljoint, if possible, they can travel far and fast when they leave.
Old Jan 9, 2010 | 07:28 PM
Go to HF and get a ball joint puller set, its cheap.
4x4YOTA
Aug 23, 2016 09:08 AM
bradahman
Oct 1, 2015 09:24 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
crash813
Sep 27, 2015 07:15 AM
Odin
Sep 26, 2015 06:56 PM
