Spare tire rack
Old Jan 3, 2010 | 06:03 AM
Jerbou71's Avatar
Spare tire rack
I have a 92 4runner and mine didn't come with a tire rack on the back behind the tailgate. I know a guy that has a 91 4runner that has the tire rack on it. Can I put it on mine or is there suports under the body on the corner were it mounts. Any help would be great.
Old Jan 3, 2010 | 06:22 AM
peapicker's Avatar
no can do. there are supports and re-enforced panels under the rack mount. there are companies that make aftermarket ones that mount on there bumper.
Old Jan 3, 2010 | 07:54 AM
lgarduno's Avatar
It can be done. I put one from a 91 onto my 95. There is a brace that has to placed into the rear corner behind the sheetmetal. Also another thing to consider is what is the max tire you are wanting to put on it. I wouldn't put anything bigger than a 35". I can post some pics later if you would like.
Old Jan 3, 2010 | 08:49 AM
olharleyman's Avatar
Don't forget you need the tailgate that go's with it as well for the locking latch and back up lights. I myself am getting ready to do a retro to my 93 the one on my 90 carry's a 35 x 12.5 well but you do lose a lot of rear window viewing area so keep in mind tire size as stated before.
Old Jan 3, 2010 | 02:32 PM
Jerbou71's Avatar
Yea I am only going to run 33's. That reenforcing piece, can I pull it out of the donar car?
Old Jan 3, 2010 | 02:41 PM
lgarduno's Avatar
You can pull it if the donor truck can be completly hacked. You will have to basically cut out the entire rear passenger tail-light area and a little more sheetmetal. I will post some pics of what you are trying to get out of the donor truck. You don't have to get a different tail-gate if you have minimul fab skills to make the backing plate to match the latch assembly.
Old Jan 4, 2010 | 02:34 AM
91 4Runner's Avatar
You can also make plates on your own to fit in behind the body and weld them in place. I used 1/8"x1" platbar and made a set to fit mine when I retro'ed the carrier on my 90. It's been holding up great for about 4 years now to a 33 on a steel rim, gonna add a gas can holder soon... (soon is relative because I have no garage to work in and I weld outside...)
Old Jan 4, 2010 | 05:20 AM
crawyota's Avatar
From: CHESTER COUNTY , PA ; by way of KOBLENZ , GERMANY
can you guys put pics up , i was thinking about doing this too.
Old Jan 4, 2010 | 02:45 PM
91 4Runner's Avatar
No you don't, but the proper gate looks much better!
Old Jan 4, 2010 | 02:50 PM
Kiroshu's Avatar
I think in late 1991 they stopped putting those tire racks on runners and they were all underneith from then on.
Old Jan 10, 2010 | 01:50 PM
Jerbou71's Avatar
How do you get access to behind to weld the re-enforcement plates? And do you have pictures of your truck? And alsoI got the rack off that truck but I 4Runner was not running and they didn't have the keys so I could not get the back window down. Is there a way to open the back door to get it off?
BushPig
Oct 29, 2022 06:26 AM
mr_manny
Jul 31, 2015 10:39 AM
HaydenConQueso
Jul 12, 2015 05:22 PM
skoti89
Jul 8, 2015 12:05 AM
