not heating up. and a knoick problem
Old Jan 5, 2010 | 03:28 PM
Gnargoyle(208)'s Avatar
my 89 22 re 4x doesnt heat up to where it should be. the needle moves about 1/4 at the very most up the temp gauge....and I have a fuuuuunny feeling this has something to do with my heater not blowin so warm....and I need that sucker to, Im in boise,id.its a lil cold out.\
where should i be stickin my nose at on this problem? im kinda lost.
also, I pulled my engine codes a while back and got one for a knock sensor... I found the sensor today and the wire is mostly gone. their is wire comin off the sensor to a connector, which both M and F ends are attached, just no lead off the connector. where does the other end of the wire run? im assuming somewhere to the harness?
thanks for any help/insight.
Old Jan 5, 2010 | 03:54 PM
Matt90V6SR5's Avatar
On the operating temp of vehicle,have u tried replacing the thermostat?
Old Jan 5, 2010 | 04:11 PM
no i havent. its been parked for awhile and I havent even really touched it since. untill sunday. I wrastled up a accelerator cable finally and got it runnin.
and this is where im at now.
Old Jan 8, 2010 | 03:09 PM
Update gnargoyle?
Old Jan 8, 2010 | 07:20 PM
none yet.its been a cold drive to work....been busy with work and school startin back up. makin time in my schedule this weekend to take a crack at it.
any advise?
Old Jan 9, 2010 | 02:43 PM
Arcticman's Avatar
I had the same problem with mine, engine running cold. So I changed the thermostat earlier today. Usually when thermostats stop working they dont open, and the engine overheats. So this was different.
Because I did not see anything wrong with the old thermostat, I boiled them together on the stove and too my surprise the old one opened way sooner then the new one.
The process of changing the thermostat was about 1 hour.
Advice: be careful not to damage the rubber seal on the rim of the thermostat. You will problably reuse it.
Old Jan 9, 2010 | 02:50 PM
shaeff's Avatar
Huh? It's like a fifty cent item from the dealer. And t-stats from the dealer are inexpensive enough for me to buy there as well. Many parts store t-stats are crap in comparison.
Old Jan 11, 2010 | 07:44 PM
i changed the t stat yesterday...i mean actually put one in.The PO didnt have one in. DOH!
it blows warm air but cools a bit at cruising speeds( 65 mph on the freeway), is this normal for older yotas?
also, where does the knock sensor hook up to? I found it, their is a wire and connector coming off of it, but it ends at the connector. and I have no idea where it goes to...
thanks yota gods.
Old Jan 11, 2010 | 07:57 PM
toyota4x4907's Avatar
For an older Yota, I would say yes. Yet, in my '93 I would be sweating in a t-shirt cruising at 65mph when it was -40F ........Best heater ever.
Try putting a piece of cardboard in front of the radiator when you go on longer drives. I notice a significant difference at the same temp when I do this. Just dont forget to remove it when it gets warmer!
Old Jan 11, 2010 | 08:08 PM
ahhhh the old bum house cardboard mod. I'll try it out tomorrow. next few days are supposed to be cold.
Sleaker
Aug 26, 2020 06:03 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Yota.Jay
Jul 23, 2015 08:08 PM
rushw
Jul 18, 2015 01:46 PM
the1998sr5
Jul 16, 2015 06:20 AM
