Engine surging while stopped.
Old Jan 9, 2010 | 06:11 PM
1985yoda's Avatar
My 86 22RE started surging last week. It only does it while holding the brake down. I checked the booster check valve but it seems to be working right. Any ideas?
Old Jan 9, 2010 | 06:13 PM
toyota4x4907's Avatar
set timing and idle to factory specs. make sure the coolant is full.
Old Jan 9, 2010 | 06:16 PM
yoterr's Avatar
x2 if ur idle is set to high it will surge when the brakes are applied, long story short...
Old Jan 9, 2010 | 06:19 PM
Mandi's Avatar
I'm just wondering does it do it when have it in park or just drive and when you have your foot on the brake?
Old Jan 9, 2010 | 06:42 PM
1985yoda's Avatar
No park or drive, 5 spd. I'll check the idle, thanks guys. Funny you should say check the coolant, After the truck sits over night it will push all the water out of the bottle. I can fill it back up and it will empty the bottle again. Changed thermostat and rad cap but same thing.
Old Jan 9, 2010 | 07:08 PM
sounds like your head gasket is leaking.
Old Jan 9, 2010 | 07:17 PM
Mandi's Avatar
ya I agree, I think its the head gasket cause my truck was out of coolent and I continued to fill it up and then like a month later my head gasket blew and sry didnt see that it said that... my bad.
smthwsn357
May 1, 2024 07:28 AM
icentropy
Sep 16, 2020 02:47 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
