- Looking for Shade
- Need 3vze help...
- Rust Repair Thread, Lots of pictures
- Protecting My Trany.... dumb question...
- 3vz-e CAM REMOVAL NOTICE!
- Injectors, year model differences?
- Water Pump replacement, What else while im there?
- Noob question about 22RE
- exhaust performance
- 5.9 CTD into 2nd gen......
- Swapping 3.0 for a 5.0?
- Possible Lean Condition on Full Throttle
- Quick Coolant Ques...
- Idle Problem
- Anyone have a negative experience with the engine builder kit?
- need some 22RE help please
- why do so many people hate our trucks?
- seat
- My truck ran good this weekend
- very bad vibration at 1/4 throttle??
- grill painting
- Rear output shaft seal
- 17" Rims on my 92 runner?
- A/C temp
- 2wd speedometer gear options?
- Its Tuff But Someones Gotta Do It PICS
- Suggestions for a 1992 4Runner
- Best thermostat for COOL
- help me pick a paint job!
- cam adjuster bolts
- '88 pickup, V6, 4x4: removing oil pan
- EARLY 2nd TIRE RACK
- Wheel backspacing?
- Do you live in phoenix and want to lend a hand????
- zing zing zing noise from under the hood
- how to correctly bleed the clutch??
- exhaust systems
- Worth SAS w/ out lockers?
- ATF in 22re...
- Pullin a vacume
- Looking for cheap Horsepower
- dei cry thingy.
- Fuel, spark, ect problems
- distributer problem
- How Much Air Time Have You Gotten?
- cant figure it out
- Ride Quality
- Looking for '97 Cruiser coils
- not engaging 4 low
- Ok, another dumb question.....what goes here?
- Should my 4wd stick heat up?
- New (to me) 4Runner
- which tranny cooler lines go where
- Is this a deal?
- Do I need those "guides" to assemble my rocker arms onto the cylinder head?
- door panel
- splashing/sloshing sound when cold
- 90 22RE 4-speed surging at 40 to 45Mph in 4th gear
- AmP Gauge Help
- Driverside mirror
- 88 4Runner Rear Bar - fits what else?
- Do You Know? Will They Fit?
- 140K and a head job already? Advice on new purchase
- help me pick a wheel 16x8 black
- what gears do i have
- any pics of 31x12.50 tires?
- Body Lift and Brush Guard
- New Tire Time....?
- Brake Upgrade Options?
- Truck wont start, and its not the battery Ideas????
- Rear axle is leaking, have important question.
- 83 toyota axle or 1-ton military axles
- options/decisions on what to do next.
- Timing Belt Tensioner NEED PICS
- Pics of my new 4runner on 35's
- CV Boots
- Intermittent Loss of Throttle/Engine on 22RE
- Squeaking sound
- quick question O2 sensor purchase
- Roof Rack Mounting
- timing belt , tension
- Emergency Brake, Emergency
- What do I torque the water pump nuts/bolts to?
- SLO Craigslist G52/54 transmission - twin stick
- Just bought a 94 Runner What Should I do?
- 148K and head gasket finally blew...replacment questions please
- Help Asap ! Bolt On Crank Shaft
- e-brake
- A/C Condenser and Compressor Compatability
- Any specific year for 3.0 block?
- Ignition problems. Any way to check the Igniter?
- True flow air filter for 87 4Runner
- 22re - head gasket leak w/ no water/oil mix??
- 3vze: Thorley vs Downey headers
- nother timing belt install question
- Tailgate window motor mod
- faulty jumpstart fried something, no power
- 33x10.50 boggers...???
- Header for 93 22re Pick Up 4x4
- Installed some goodies today
- Shifter seat and bushing replacment!
- Couple engine block questions.
- removing headlight assembly on 2nd gen
- Aftermarket Hood Air Intake ???
- What oil should i be running !!!!!
- rear bottom seat bolts for an 88 4runner
- Manual Hub Swap ?'s
- Head gasket?
- My First Truck,MINT 94SR5 WITH ONE PROBLEM......
- Tranny/t-case fluid
- Digital Gauges In Dash
- Can't get freon to go in
- ring gear diameter
- Ignitor, rpm sensor anything to worry about?
- Long shot conversion.
- Loose Timing Chain Suddenly
- Horrible Noises, Horrible Smells Brought a tear to my eye and my heart dropped.
- Tachometer!! in an 88 pickup
- bolt on v.s. welded rock sliders
- Eazey peazey dome light question...
- torshion bars
- intercooler
- My Story
- 22RE-High Idle Problems (and a few others)
- Dodge 5.2 in '90 4Runner
- Think I sprung a head gasket leak--what do ya'll think?
- a 302 in my runner???
- Front diff / carrier case 94 4runner
- Wabfab's Shifter Bushing...
- Stuck at work - truck won't start.
- 88 Pickup How to get the dash off!
- A/C fuse blows
- Rebuild in SO. Cal
- Looking for local advice in a pinch.
- I need repairs, Suspension/Stablizer?
- clutch problems and questions
- is ripping the back bumper off unlawful?
- Another failed smog thread
- Is my 1st Gen window switch bad?
- brakes, wheel bearings, ball joints
- Winch + Accessories - am i missing anything?
- Integra seats
- Anyone installed a center support bearing?
- Skyjack shock part numbers
- 383 chevy stroker
- AUX lights.... What are you using?
- MC Shift seat ordering
- running 35's, gearing?
- 86 Runner - Need Guidance on Front Hub Re-assembly after brake Rotor replacement
- Please excuse the ignorance
- Busted timing guide?
- 1993 Head Gasket
- fuel filter
- leak from water pump gasket ,water pump
- bouncing
- Are the headers interchangeable from 88-94?
- Identifying my transmission
- Thinking about getting a PU?
- regearing and exhaust 94 pickup
- Hub Cone washers - Part# ???
- Value Of 22r Block Bored 40 Over
- wheel bearing going bad?
- 1986 4 runner 2.4 DIESEL TURBO
- 95 4Runner Leaning
- Sealed Beam Projector headlights!
- Bogging, no power. High EGT
- Pics of my 1986 4runner
- so im thinking about bj spacers.....?
- Tryin to get my doors off
- 2" BJ spacers?
- Auto Trans. Issue
- Exhaust air tubes...
- Timing belt destruction
- Got Rear Ended on the Highway
- Hubs won't come off!
- Fun in the sun at Silver Lake
- Best spark plugs for a 3.0 ?
- :help: Just Wondering... Could You Help Out?
- Firing Squad
- hydro or nitro shocks?
- 4runner now runnin!!!
- Engine Temp Problems??
- Different trannys that will bolt behind the 3vz
- Looking for pickup need advice on motor
- Lock set
- 22re Dies in gear
- my Rig, 90 toy w/tacoma conversion, Pics inside
- 4WD not engaging
- Water wheelin video
- Timing chain, is it time?
- pin hole rad leaks
- free 02 sensor?
- Fuel Tank Flex Line Feed Fitting 14mm x 1.5
- Oil pump question and pic of my engine.....
- Checking for codes
- Ebay's latest disaster.....at least its a solid axle
- dry bearing sound
- Need help with compression check????
- 22re dies
- light
- AC Electric Fan Troubleshooting
- will this work?
- I hate accidents!
- Using Diagnostic Connector for timing and Codes
- Roaring Noise from fan on 95 4Runner
- good source for switched power
- good source for key on power
- Some advice
- Need advice on getting rid of rust
- getting moisture out of A/C
- Removing Anti-Lock Brake Sensor??
- rear wheel wobble.....
- Front Bumper Valance Modification
- 14inch magnaflow video
- Subwoofer wiring, amp cutting out?
- A visit to ARB and a great experience with Dudebud
- What ratio might these gears be?
- Tailgate 91 4runner
- Smog a 3.4 swap questions
- front bumper options
- where can i get this part?
- nascar 07
- 94 4runner turning radius right vs left? 4WD?
- Actual water temp is reading 220 degrees-ideas please?
- Knock sensor nightmare
- Bad MPG after top end rebuild and y pipe mod!!
- Help please....emergency...sensor ID
- Just washed the muddy runner(56k no)
- Auto Trans Flush Experiances.
- running with the tps unhooked?
- One 12oz 134a can, and the pressure is high?
- Q: Classic Fuel Line Rot
- Hi! / Low oil pressure
- Anyone have these hiclearance fenders on an 89-95?
- power windows
- Why does synthetic oil price go up?
- Custom Wiring Harness
- -'88 Snorkel fit on '89-'95 vehicle?
- Over heating still!!!! need help asap!
- sway bar raised after Downey cable lock conversion
- 22RE Studdering/Hesitation/Backfire HELP please!
- No power steer at idle
- someone who has a TBS on a 2 gen tell me..
- Why does A/C cycle?
- New Cat...
- 4 cyl. 4Runner question
- 84 pu 22r work in 86 pu?
- 1 piece driveshaft
- truck/4runner fender compatibility
