Why does A/C cycle?
Old Jun 6, 2007 | 06:18 PM
Lifelongtoy's Avatar
Question Why does A/C cycle?
What causes it to do that?
And how cool would it be with only one can, 134a?
Old Jun 6, 2007 | 06:54 PM
TNRabbit's Avatar
ALL air conditioners cycle, too keep from getting too cold & freezing up.
Old Jun 6, 2007 | 07:17 PM
InternetRoadkill's Avatar
Some will cycle when they are low on gas. There is a safety switch which detects low gas pressure and stops the compressor to prevent damage.
Old Jun 6, 2007 | 08:30 PM
FredTJ's Avatar
They also cycle when the pressure is too high from overcharging, clogged expansion value or evap. etc.
To the original poster:
You can't just "dump a can of R134A in" and hope that anything good is going to come of that act.
Fred
Old Jun 6, 2007 | 08:58 PM
YodaPala's Avatar
They cycle when the evap coil temp gets right above freezing for optimal performance. If the thing doesent cycle correctly, (short cycling) chances are that there is a leak ie. not enough refrigerant to compress, back pressure dives too quick and gives a short cycle. Or the other way around, might be overcharged (too much refrigerant to compress, floodes accumulator, or a restriction) but its easy to charge most Yotas thanks to the good ol' sight glass "when the bubbles quit, quit charging and you are good to go!"
But remember, when charging 134a you gotta charge it in a liquid state because its a blended refrigerant.
Old Jun 7, 2007 | 03:59 AM
ssupercoolss's Avatar
lots of good info stated above. if its blowing good cold air, on a warm day, it should cycle on and off. on the real hot days is may not cycle, since its working so hard to cool. if its only blowing cool air and cycling, its probably low. the low pressure switch is shutting the compressor down.
yodapala - nice SS.....i just sold my in feb. last of the big fast cars.
Badlander
Oct 10, 2015 08:05 PM
Ktm526
Oct 7, 2015 05:14 AM
bryan34w
12
Sep 30, 2015 02:50 PM
JamesDINAN
Sep 22, 2015 05:37 AM
Tacoma1313
Sep 8, 2015 01:27 PM
