Ignitor, rpm sensor anything to worry about?
Old Jun 13, 2007 | 05:55 AM
co4rnr's Avatar
I posted this earlier so here it goes again. I have code 6 showing up and was wondering what I should do about it. The truck still seems to run fine. I jsut don't want to get stranded. Code 6) Engine Speed (RPM) sensor, circuit Ignitor or circuit, distributor, ECU. What could have caused this and how do I fix it?
Old Jun 13, 2007 | 10:32 AM
dcg9381's Avatar
It means there is a signal issue in the ignition system somewhere. It's going to be hard to find unless the truck quits running or it constantly throws the code and you have access to an oscilliscope.
Most mechanics would start replacing parts (guessing) until it goes away.
I don't know anything about the engine speed sensor, however.
HAve you looked at the factory service manual in regard to debugging this code?
Old Jun 13, 2007 | 07:03 PM
co4rnr's Avatar
No, I have not looked at the FSM. However, I know a mechanic with a oscilliscope I think. What he has is something that looks like a computer that has a graph of how the engine runs. It looks like a sin curve. Would that be able to tell me what is wrong?
Old Jun 14, 2007 | 09:38 AM
dcg9381's Avatar
It'd be able to show you the ignition signal. If something was getting spiked, had noise, or was producing a bad signal you'd be able to see it. It requires some electronics experience.
Old Jun 28, 2007 | 09:31 PM
co4rnr's Avatar
Just thought I would let everyone know that this was a simple fix. I unplugged the coil to crank the engine and forgot to reset the ECU after that. Unpluging the coil set off the code 6.
Blamalam
Mar 12, 2022 07:34 AM
montanatruck
Feb 26, 2017 07:07 AM
jetpilot
Aug 15, 2015 06:48 AM
Steven.m.paulk
Jul 24, 2015 01:44 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
