Front diff / carrier case 94 4runner
Old Jun 12, 2007 | 05:47 PM
tktmsa's Avatar
While troubleshooting the non engaging 4wd system in my 94 4rnr I came across a 1/2 inch hole in the front half of the carrier case, nice sharp rock I'm sure (vehicle is new to me).
A couple questions: can I just replace the front half, or would the whole front diff need to be replaced. How can I tell what gear ratio I need 4.10, 4.88, 4.56 etc etc etc . Any other advice or sarcastic comment is welcom.
tk
Old Jun 12, 2007 | 05:50 PM
Bigblock's Avatar
What do you mean by front half?There's a code on the door sill plate that says axle.Get us that code.
Old Jun 12, 2007 | 09:25 PM
tktmsa's Avatar
Front of the carrier case on the from differential, right here:Front diff / carrier case 94 4runner-addlocation.gif
Low on the front next to the actuator.
Old Jun 13, 2007 | 05:14 PM
leebee's Avatar
if you are referring to the actual front diff, you will need to replace the entire diff, there is no 'cover' plate as a jeep has.
lee
Old Jun 13, 2007 | 06:37 PM
tktmsa's Avatar
EDIT G254 = 4.55 right? would this be for both rear and front?
Old Jun 13, 2007 | 06:40 PM
tktmsa's Avatar
lee
Hmmm... I'm looking at a manual that shows how to take the front carrier case off the Differential; 8 bolts, a whack with a hammer then putting back-on gotta use some sealer goo - and Bobs you're uncle.
Jun 1, 2021 01:51 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
lledwod
Aug 30, 2016 01:03 PM
colinmil
Jul 6, 2015 04:03 PM
Jnkml
Jul 6, 2015 01:20 PM
