Busted timing guide?
Old Jun 11, 2007 | 06:31 PM
2WDoffroadx's Avatar
I seamfoamed my 1991 Toyo PU, 2wd 5spd 22RE few days ago. Ever since revving really high to get all the gunk and exhaust out, i've been hearing a scratching/chattering kind of sound. I heard it for the first time when i was idle at a red light..it was LOUD and very distinct. I revved it once and it died down. Since then I've been hearing it here and there. Never really at a specific time. Just spurratic times.
It sounds like its coming from around the intake...Could it be the MAS? I'm not sure though because I can never hear it when I'm under the hood. Only when I'm driving. What could i have broken by revving it too high?
I dont recall ever revving it that high before.
I heard that the timing chain could have busted one of the plastic guides..How can I test to see if this is the case? How much is the replacement for these including labor?
It hasnt affected the performance, but I hate the noise and want to get rid of it because it's not normal. Does anyone have any idea what this could be?
Old Jun 11, 2007 | 07:40 PM
TNRabbit's Avatar
Drop your oil pan; if there's plastic pieces in it, you know what happened! i think you can also remove the valve cover & look down inside the chain housing.
Old Jun 11, 2007 | 07:44 PM
I'm not due for an oil change for another 1,400 miles or so. If i drop the pan and get rid of the oil, can I just slap it back on and pour some new oil in?
Old Jun 12, 2007 | 05:15 AM
PirateFins's Avatar
I wouldn't since your at about the 3/4 mark as far as milage goes.
Just pull the valve cover off and shine a light down into the timing chain housing. It is easy to see. but you definitly want to check it out before it wears a hole in the water pump part of the cover.
Old Jun 12, 2007 | 06:03 AM
trythis's Avatar
sounds exactly like what my chain was doing when it was worn out. You wanna check that ASAP.
Old Jun 12, 2007 | 06:42 AM
rdlsz24's Avatar
x2, valve cover removal is only 4 bolts and a couple hoses
Rob
Old Jun 12, 2007 | 02:25 PM
A warn chain goes OVER time..There hasnt been any sign of it until i revved it really high ONCE.
Also, its not a constant or intermintant sound.
Eggslinger
Jun 8, 2019 03:32 PM
razorman8669
Jul 12, 2015 12:13 PM
shar
Jul 9, 2015 12:38 PM
