22re Dies in gear
Old Jun 10, 2007 | 06:58 AM
Sonofmayhem's Avatar
22re Dies in gear
It runs awesome until it's in gear then it dies on me... I drove it in 4 low for a minute trying to climb over a log in 2wd, nothing. Then i went forward and it shut off. if i start it it will start then just die immediately afterwards.
Old Jun 10, 2007 | 11:30 AM
I adjusted the TPS and it seemed to fix it.
Old Jun 10, 2007 | 09:42 PM
Doing it again. Tommorrow im gonna check the tps again, any ideas? if i keep the starter engaged it keeps it running... Is my ignitor bad?
Old Jun 11, 2007 | 08:24 AM
Now gas is dripping out of the filler neck. I did fill it up and put in 44k the other day but drove it about 20 miles.....
Tps was in spec too.
Old Jun 11, 2007 | 08:25 AM
Bunta Fujiwara's Avatar
I
'll
help you fix it...
Old Jun 11, 2007 | 08:29 AM
Great. I am thinking fuel pump. Because if i keep the starter engaged(key in start position) it will stay running....
Old Jun 11, 2007 | 08:30 AM
would you like a dynamic Murasama-Toyota 22R-GTE R-EGGFIHR/MASS AFM/TCCS-HFI diagram???
HFI stands for "Hydraulic throttle body Fuel Injection"
R-EHGGR Means Egg-based Hydraulic throttle body Fuel Injection with dynamic intelligence and dynamic VVTL-i TWIn CAM...
Old Jun 11, 2007 | 08:32 AM
Mine runs like crap, and sounds like it's carbed after I sprayed half an aerosol can of high-quality non snake-oil carb cleaner in the air filter box... without the filter and with the engine off... I can lick the carbon deposits out of the exhaust if I want to, but running a plant through my engine first is not what I want to do, so I just use my hands and fingers and wash 'em off with Fast Orange...
Old Jun 11, 2007 | 08:33 AM
hope that helps...
Old Jun 11, 2007 | 08:38 AM
Fix your exhaust system to stop the rich burn and burn lean for a few days to crystallize-quench-strengthen your engine...
then...
maybe... you'll ask me... to help out, again, and maybe, you should replace that fuel pump...https://www.yotatech.com/forums/imag...s/grouphug.gif
I love you guys... you are all so wonderful...
Thanks, Boss, for letting me come back (that's Corey)...
I'll have to tell you about Nikita, my old red '85... maybe write a viking story and illustrate a Viking-style Garfield comic strip with Toyota stuff... post it sometime...when it's done...
I'm 25% Norse in real flesh-and-blood life!
FEAR MY 22R WRATH...
I will burn your engine... if I want to. But I don't...
JAVE a Hot RIze DAY, MON!
Old Jun 11, 2007 | 09:01 AM
What?
Old Jun 11, 2007 | 09:22 AM
Stomis's Avatar
I too am also lost on those responses.
Old Jun 11, 2007 | 08:39 PM
Ok anyone else? new tps in and still no dice..... Need ideas asap!
Old Jun 11, 2007 | 09:10 PM
Tps has no resistance? The new one had 550 resistance earlier today, now none?!
Old Jun 12, 2007 | 11:14 AM
Now i am looking to see why the truck won't run unless you keep the starter engaged. It will stumble on its own for like 2 seconds, then die...
Old Jun 12, 2007 | 12:22 PM
Corbit's Avatar
Have you tryed jumping the fuel pump to run full time ? Or open the door on the AFM to listen for it to kick on .
Yo Bunta , put the pipe down bro....your good.
Old Jun 12, 2007 | 02:19 PM
tmisiak's Avatar
Hey sonofmayhem, give my tech dept a call and ask for John in technical. I know they can help 877-505-2501
Old Jun 12, 2007 | 06:01 PM
Sweet will do tmisiak.
I will try that corbit.
Thanks
Old Jun 13, 2007 | 10:20 AM
b u m p
Any other ideas?
Old Jun 13, 2007 | 11:16 AM
gametom's Avatar
did you test the maf
