Worth SAS w/ out lockers?
Old Jun 16, 2007 | 08:35 PM
Adawg_08's Avatar
I have an 88 4runnner and would love a SAS in the front. I don't like my IFS. But, if I did a SAS I wouldn't have money for lockers. I can get some
33's cheap and find some 4.88 3rds in a yard somewhere. I can get a front axle too.
I also thought about getting a Detroit rear and just wheelin' the IFS for now. Save and do the SAS correct with locker's, 5.29's, 35 Crawlers or 35 BFG MT's. I would go the Trail-Gear IFS elimetor kit 4" kit.
I could make it further with a locked rear than open/open right? But the lift is just so BADA$$.
I'm am getting sliders and making a rear bumper. Are the detroits any good? I didn't think i needed one that bad until I went wheelin' the other day down Yellow Creek. I couldn't crawl up a little rock in the trail. maybe a foot high? (maybe). I made it up I just hit it a little harder, but a rear locker is cheaper and make it a better trail rig than SAS correct.
What do you all think I should do?
Old Jun 16, 2007 | 08:52 PM
Elvota's Avatar
Your post may end up opening another can of worms...
But sounds to me like a locker at this point would be your best bet. SAS will not get you as far as a fully locked rig. IFS will probably take you more places than you can imagine... maybe just work on your lines a bit with your current open/ open situation. A lot of wheeling successfully is just understanding what your vehicle is capable of and picking the lines that will work.
I think you'll find that most IFS users like to stay at 33" or under to help prevent wear and tear on the factory front end.
Old Jun 16, 2007 | 08:53 PM
d0ubledown's Avatar
weld the rear. sas the front. done.
Old Jun 16, 2007 | 09:21 PM
MudHippy's Avatar
Picking up can opener...opening can...Dude, SAS, then lock the rear. IN THAT ORDER. I've seen rigs with solid axles and no lockers, do better (on occasion) than solid axle or IFS rigs with lockers fr/rr. Not to mention how muck I think IFS sucks the big one, and have never been impressed by mine or anyone elses I've witnessed. I have to make do, for now, and may settle for a rear locker first myself, due to budget constraints. If trail ability is the goal, the answer is way too obvious SAS, lock what you need to after that. The things you have to MAKE your IFS do(IF you can), a solid axle w/leaf spring front suspension will do easily.
Old Jun 16, 2007 | 09:42 PM
Tofer's Avatar
Sponsor
i SASed first and i am still stock 4.56gears and open/open... it would have been nice to regear and lock at the sametime but i was short on money. gears and lockers come soon though hopefully... i say SAS first.
Old Jun 16, 2007 | 09:57 PM
fillsrunner4's Avatar
I sased and locked the rear ARB. I wish I had saved for a HP ARB for up front and either spooled or detroited the rear. Choices Choises. Plan on your goals for your truck and save money and do it right to how you would untimatly like to see it. If you plan on extreme mods I would save and build parts and just wheel what you have now. You can go alot on IFS and if you need to ask whether to SAS or not, Now is probably not the time. SAVE and do it right and do it all yourself thats the best way for sure
Old Jun 17, 2007 | 06:15 AM
waskillywabbit's Avatar
Invest in a rear locker now and wheel your IFS until you can afford to do the SAS.
Locked in the rear IFS will outdo an open 4WD SAS anyday on most obstacles, but there are lots of other variables like gearing, tire size, etc.
Old Jun 17, 2007 | 06:22 AM
dijlop's Avatar
idea, u buy me a front axle kit, and buy urself the rear locker, and i'll use the sfa to convert to 4wd, and then we'll compare.
doesnt that sound like a great plan?
Old Jun 17, 2007 | 11:39 AM
tc's Avatar
tc
Lockers will take you farther than ANY suspension/lift mod. Also, I don't see any reason to SAS if you're "only" going to run 33's.
Lock it now, get A LOT more experience 'wheeling, save up and SAS when the IFS is truly the limitation.
Old Jun 17, 2007 | 11:41 AM
EUROJulian's Avatar
Irish Traveller? Yeh, we saw the movie...
Old Jun 17, 2007 | 12:33 PM
dijlop's Avatar
umm... i havent ever seen the movie. i was just tryin to get free stuff. oh well.
Old Jun 17, 2007 | 12:51 PM
BeaterToyota's Avatar
I ran 32"s, a rear locker, and dual cases for about 3 years before I "needed" a SAS. I regularly wheeled with guys with SFA rigs on 35"s with a locker or two. I just had to learn how to drive better and pick my lines.
Lock the rear, learn to drive, and you will know when you need a SAS.
Old Jun 17, 2007 | 12:55 PM
gilby4runner's Avatar
get a locker and save for the SAS. That way you can build it all at once instead of partially completing your goals.
Old Jun 17, 2007 | 12:59 PM
dijlop's Avatar
or trade me and dont ever worry about what the next step in the 4wd world should be. lol. (yes im persistent.)
Old Jun 17, 2007 | 01:43 PM
EUROJulian's Avatar
Yep, go watch TV or sompthin`... Movie series is The Riches on FX.
Old Jun 17, 2007 | 02:00 PM
nc994run's Avatar
From: raleigh, nc for school chapel hill, nc for home
If all your gonna do is try and get him to give you free stuff, you might as well hold your tongue and not post in this thread
I vote for rear locker and wait on the SAS. I've wheeled my 3rd gen (i know they;re different) open/open for 2 years, and am just now needing to add a rear elocker because i pushed what i had to its limits, now time to push the limits out a little bit further
Old Jun 17, 2007 | 03:08 PM
AxleIke's Avatar
No lift, stock IFS, and two lockers will get up up stuff like this. Sas w/out lockers will not.
Old Jun 17, 2007 | 06:28 PM
Adawg_08's Avatar
Well, I talked to some people to day and am getting a front axle.
I will wait for the sas but I will have the axle. Start rebuilding this one, 5.29's, detroit, new bearings, seals, whatever needs done. I really want a locker in the rear.
I'll beat the IFS until it's seen some bettter days.
I was only going to run 33's because I could get them cheap and it's my daily driver. But 35's are what I'll run.
I turned in an app. at Mikey D's. I am saving for a Detroit rear. You have to set Ring & Pinion gap after, correct? I could get some 5.29 on 31's? (bad idea?) Or 4.88's? It would be nice to get a little lower gears. You know...
Old Jun 17, 2007 | 08:10 PM
tc's Avatar
tc
Good decision.
If you are planning on 35's, you need 5.29 for manual transmission or 5.71 for automatic. Do gears at the same time as lockers, otherwise you're paying for installation twice.
Old Jun 18, 2007 | 08:35 AM
Adawg_08's Avatar
What are stock brakes on 35's like? I actually read SAS instructions and it's not that hard at all. I REALLY WANT A SAS. But, it's very expansive.
