What ratio might these gears be?
Old Jun 8, 2007 | 10:49 AM
KTMR1der03's Avatar
I have a '90 4runner with 4.10 gearing on 32x11.50. I'd like to go to 4.88's. A buddy of mine has a rear axle and front end from a '94 Auto trans 4runner. Would that mean they are either 4.56's or 4.88's due to it being an auto? Also, how could I check what ratio they are without the vin number, thanks.
Old Jun 8, 2007 | 10:51 AM
Stomis's Avatar
You dont use the vin number. You use a code on the inside jam of the driver door. If you have them out count the ring teeth and divide that number by the pinion teeth.
Old Jun 8, 2007 | 11:24 AM
MudHippy's Avatar
The axle code may be in the engine compartment on the firewall directly behind the engine. Read the link here to find out what code means what.
http://toyota.off-road.com/toyota/ar....jsp?id=274535
This link is found on the Wiki page, in the FAQ for the model years it applies to. For future reference.
Old Jun 8, 2007 | 01:48 PM
KTMR1der03's Avatar
He no longer has the whole truck, just the rear axle and the front end. Is there a chance that it would also be 4.10? Or for sure will it be 4.56\4.88.
Old Jun 8, 2007 | 04:03 PM
notanymore's Avatar
well if its only the axel you spin the driveline 2 times and how many times the tire spins is the gear ratio, aproxemently. it helps to make marks on the tire
Old Jun 8, 2007 | 04:11 PM
89-4Runner's Avatar
my money would be on 4.56 unless it was a limited...
Old Jun 8, 2007 | 07:12 PM
gonzo's Avatar
My 95 3.0 5spd with 31's came with 4:56's. A friends 95 3.0 auto with 31's came with 4:88's if that helps.
Old Jun 9, 2007 | 11:47 PM
KTMR1der03's Avatar
I'll give spinning the driveline a try. But thats all I really wanted to hear, is that it will be a lower gear ratio for sure. Thank you
Old Jun 10, 2007 | 12:02 AM
MudHippy's Avatar
That you can count on, lower gears I mean. The other likely candidate is 4.30. I have 4.30s that i swapped out of an automatic 4Runner on my truck. Never heard of an auto with 4.10, but strangely I have heard of automatics with 3.90s. I'm thinkin' they were 2WD, anyway they would be rare on a 4WD that's for sure. O.K., I checked that link(above), that's where I seen that. Says some 81 4WDs had the 3.90s, and the 2WDs.
RatOmeter
Oct 22, 2015 03:17 PM
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
