90 22RE 4-speed surging at 40 to 45Mph in 4th gear
Old 06-15-2007, 10:09 PM
imtxn's Avatar
OK. Here's the story Guys. Valves are set at 0.008"-in & 0.12"-out, no rocker clicks louder than any other. Idle set right at 750 rpm. IG Timing is is set at approx 6 degrees btc. It doesn't hunt at idle at normal running temp. Engine has about 150 miles on it. I haven't driven it faster than 45 except once at 50 for a couple of minutes since the rebuild. I have been accused of not loading an engine when I drive. I drive 9 miles to work and around a small town. I suspect the surging occurs when I'm driving in a low torque range, but it's weird because the truck doesn't surg at lower speeds when I'm in 4th. It didn't surg at 50!!
I hope you folks have some ideas because I'm stumped. Me
smthwsn357
12-04-2023 02:08 AM
mskalmus
05-28-2017 07:51 AM
deepmarsh
08-06-2015 03:44 AM
Jnkml
07-06-2015 01:20 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: 90 22RE 4-speed surging at 40 to 45Mph in 4th gear
