where can i get this part?
Old Jun 8, 2007 | 07:57 AM
95RunnerSR5's Avatar
On a 1995 3vze
The air control valve on the back of the power steering pump?
The TVV that is part of the EVAP system mounted on the back of the intake manifold?
I already have epoxy'd these together once or twice and am tired of it.. i need a new one. thanks
Old Jun 8, 2007 | 08:03 AM
mudbutt's Avatar
The dealer is the easiest. The TVV is like 30 dollars and the idle up valve is like 60 dollars.
Old Jun 8, 2007 | 08:12 AM
appreciated
Old Jun 9, 2007 | 06:59 AM
farmerj's Avatar
I just disconnected it. Haven't noticed any difference in performance.
It is there to create a vacuum leak to increase you idle when you turn your steering wheel at low engine speed.
Not something I try to do as you are applying excess torque to your frame and steering box mounts.
Areas I have seen get broken on both Toyota's and chevy's
88sasturbotoy
Jan 30, 2026 01:57 PM
May 20, 2016 10:27 AM
Fundy Rider
Jul 16, 2015 01:35 AM
akaphilly
Jul 9, 2015 02:34 PM
