FS[GreatLakes]: 22RE performance and stock parts (pic heavy)
Pics are below!
I have a few different performance parts for sale from a motor I pulled apart that was in my truck, it had bottom end issues. There are some extra stock parts as well from the original motor. ~4k miles on all parts
Pics below:
-Keith Black Hypereutectic Performance Pistons KB323-75mm (for .030 over bore)-4 of these.
These are $840 for a complete set of 4.
The skirts are in great shape, there isn't any wear. BUT, 1 of them has some scuff/nick marks on the head of the piston. See picture. This could've been from a dry start, I'm not sure. None of the valves were damaged, so I'm not sure what it (briefly) nicked.
The set can be polished for $60-75 depending on the shop near you, and then they would all be usable.
All 4 for $400!
-Rocker Arm Assembly. One of the rocker arms is scuffed, these are about $15 to replace. It needs to be cleaned up a little and is missing 1 stud (see pic). Go for $200 everywhere I see them...$65(+s&h)
-Fuel rail and (3)injectors. $55(+s&h)
-22re exhaust manifold- no cracks that I can see. $35(+s&h)
-22re High volume oil pump (from the turbo motor) with a water pump assembly, all worked fine, needs to be cleaned a bit but no issues. $50(+s&h)
-22re valve cover- no cap, would need gasket. $25(+s&h)
-22re Oil pan. From early 90's 22re. No drain bolt. $25(+s&h)
Sold:
-SOLD LCE Engineering 20R/22R/RE/RET 4" triple groove underdrive pulley- This costs $140 shipped from LCE. In great shape, I will give it up for $85 shipped.
-SOLD LCE Adjustable Cam Gear Single Row 20R/22R/RE/RET. This is $100 shipped from LCE. Great shape, and red, which looks cooler. $50 shipped.
-SOLD 22re Pro Top Line head. This was ported and polished and had a set of heavier duty springs installed. The machine shops I took this two told me it could be bored out or line bored and still be used.
With the valves and all in it still being good, $50 + s&h
-SOLD 22re engine mounts- solid, just some surface rust, held the motor in fine. $20 (SHIPPED)
-SOLD -22re intake manifold, upper and lower and throttle body. From the original motor. Worked fine. These seem to go for $125-150 used. I'll take $60(+s&h)
Pics below:
All 4 for $400!
Sold:
