New Cat...
Old Jun 6, 2007 | 03:27 PM
BluYot's Avatar
New Cat...
Just got a universal cat from Crappy Tire and both ends are 2 1/4 but my exhaust is 2". I'll be taking it to a guy that does good exahaust work but will it matter that they are two sizes...it is only 1/4" difference. I know I've asked this in the past but can something be rigged so there are sleeves and clamps instead of welding? Anymore suggestions? Thanks in advance.
Old Jun 6, 2007 | 03:50 PM
Elton's Avatar
will be fine have it welded on
Old Jun 6, 2007 | 03:51 PM
ShortyzKustomz's Avatar
2 1/4 should slip nicely over a 2 inch pipe and should clamp decent? But why, Clamps can leak. I prefer all my exhuast welded
Old Jun 6, 2007 | 04:23 PM
BluYot's Avatar
I just wasn't sure if I wanted it welded because if I ever needed it removed to get to something it would be one piece...but then again the times that I would need to remove my exhaust will hopefully be very few...so weld eh?
Old Jun 6, 2007 | 04:42 PM
dcg9381's Avatar
You can clamp it on with proper adapters if you need to.. No big deal.
Old Jun 6, 2007 | 04:57 PM
BluYot's Avatar
Hey DCG, by adapters do you mean sleeves or the clamps themselves? I figured clamping would be alright because the rest of my exhaust has either clamps (at muffler) or bolts with the flange and gasket as they are direct fit pipes. The direct fit cat was $140 vs. $80 uni so I figured I could make something work one was or another.
Old Jun 6, 2007 | 10:22 PM
curtiswyant's Avatar
You can get cheap-o exhaust adapters at Autozone/etc for about $2 apiece.
Old Jun 7, 2007 | 01:00 AM
Jay351's Avatar
My replacement cat was bigger then then stock pipe, they just cut the flange off, slid the cat onto the old pipe and welded it in.
No leaks, works great
Old Jun 7, 2007 | 03:50 AM
BluYot's Avatar
Thanks for the responses guys...I'm leaning towards a weld...
Old Jun 7, 2007 | 10:37 AM
91muddog's Avatar
have your exhaust guy get peices of 2inch pipe and he can stretch the ends to fit each pipe perfectly, ten weld it on.
over time clamps will leak, theres nothing you will need to get to that reuires removing the cat only.
gixxer
Feb 4, 2014 05:28 PM
acousticrawk
40
Apr 20, 2011 11:05 PM
91_TOYOTA_4x4
Oct 15, 2010 01:16 PM
HAWAIIANSTYLE
Nov 17, 2009 07:57 PM
yota4life6
Apr 16, 2009 07:23 AM
