Installed some goodies today
Old Jun 13, 2007 | 07:42 PM
treknwil's Avatar
I had to go to Jury Duty today, Didn't get picked and got out at 10:00am. So I rushed home and started working on the 4runner . I install a Downey Truss, Downey 26mm bars, upper& lower Ball Joints, and the 1" ball J spacer I made. I removed the anti sway bar. Got it all done by 6:00pm. Know it pull a little to the right so a front end alignment is next. It rides a lot better than before and the sway bar begin gone its hardly noticeable. I'll put the skids back on after the alignment.
The new ball joints & 1" spacer I made
Cuts in the upper A arm To fit spacer
The spacer & ball J installed
The new Downey bars
The end result
It looks a little high in the front now, I'm either going to raise the rear or lower the front alittle
Old Jun 13, 2007 | 07:44 PM
SR5's Avatar
SR5
raise the rear for sure
Old Jun 13, 2007 | 07:45 PM
Sonofmayhem's Avatar
Wow, looks noice! What are you doing for paint afterwards?
I would take the tbars down a notch, give you a wee more flex and softer ride.IMO
bruzer's Avatar
Raise the rear.
Old Jun 13, 2007 | 07:46 PM
Elton's Avatar
looks nice
Old Jun 13, 2007 | 07:56 PM
bigtrucknwheels's Avatar
man that is one sharp looking machine!
Old Jun 13, 2007 | 07:57 PM
WCorbett's Avatar
you did drill and bolt the holes so the truss is accualy held there right?
Old Jun 13, 2007 | 08:02 PM
Jay351's Avatar
Hows the differance in ride after the sway bar removal?
Mine is junk, squeaks like a mother and the bushings are shot, I was just going to remove it all together..
Old Jun 13, 2007 | 08:05 PM
2WDoffroadx's Avatar
those fenders look aggressive
Old Jun 13, 2007 | 08:11 PM
treknwil's Avatar
I knew I forgot something. LOL Yes I did I just snapped a pic before drilling.
The ride is fine I can fill a little lean. Over all it good, but I haven't been on the freeway yet!
Old Jun 14, 2007 | 05:00 PM
CASTAIC 4RUNNER's Avatar
sweet man
Old Jun 14, 2007 | 05:02 PM
Stomis's Avatar
I agree Tbars down.
Old Jun 14, 2007 | 05:06 PM
the_gunslinger's Avatar
good lookin' truck.
Old Jun 14, 2007 | 05:22 PM
Jay351's Avatar
I tried to take my sway bar out but couldnt budge the bolts on the end links!
I don't want to break it incase I want to put it back on too
frodin1's Avatar
Looks stout. Just what trucks are supposed to be!
Old Jun 14, 2007 | 05:47 PM
treknwil's Avatar
The nuts are on the bottom side of the lower A-arm. Mine came off with ease. Spray it with penetrating oil and try again the next day, and the hole in which the nut was in was full of mud, so make sure its claened out first. As far as breaking it, go ahead its just a bolt.lol Good Luck. Wil
Old Jul 1, 2007 | 03:04 PM
treknwil's Avatar
Well I lowered the front which softened the ride a little. I put the skids back on and tested the flex a little. Looks to me that the BJ spacers and no sway bar let the low wheel drop more than before and the raised wheel to flex up more too. heres some pics.
Old Jul 1, 2007 | 03:12 PM
waskillywabbit's Avatar
Scratch the trucks hood and his butt will go up.
Old Jul 1, 2007 | 03:31 PM
Shoua's Avatar
Wow! Removing the sway bars will give that much flex? I might try that...I have the same Downey torsion bars on my truck, but with the sway bar intact. Does removing it make the truck handle any worse?
Old Jul 1, 2007 | 04:40 PM
TheGhost's Avatar
what tires and size are they? they look sick! where you get the downey bars from?
