getting moisture out of A/C
Old Jun 8, 2007 | 09:19 PM
Lifelongtoy's Avatar
Question getting moisture out of A/C
I have the grayish sludge from adding 134a to a system literally filled with water, like the evaporator was full of water. Can I just spray air into the low side and blow the sludge out the hi side. I know the proper way is to take it apart and blah blah blah.... but can it be done this way. Or is there another half ass way to do it.
I just wan't to experiment a little before taking it apart.
Old Jun 9, 2007 | 05:51 AM
Seems like it would work
Old Jun 9, 2007 | 05:53 AM
Question Getting moisture out of A/C
Old Jun 9, 2007 | 07:02 AM
InternetRoadkill's Avatar
You need to take it apart, blow the crud out with compressed air followed by a good flushing with a cleaner intended for use in A/C systems.
If the evaporator has that much crud in it, the A/C system is probably ruined.
Why did the a/c have water in it?
Old Jun 9, 2007 | 07:10 AM
mt_goat's Avatar
Is this the same truck as this thread?
https://www.yotatech.com/forums/f116/everything-new-so-why-doesnt-my-c-work-114946/
and this thread?
https://www.yotatech.com/forums/f116/my-c-destined-not-work-116445/
and this thread?
https://www.yotatech.com/forums/f116/why-does-c-cycle-117551/
and this thread?
https://www.yotatech.com/forums/f116/one-12oz-134a-can-pressure-high-117614/
If so, it would be much easier for poeple to follow and provide help if you would stick with one thread.
Old Jun 9, 2007 | 12:13 PM
Same truck different problems. But thanks for the ethical lesson.
Badlander
Oct 10, 2015 08:05 PM
Ktm526
Oct 7, 2015 05:14 AM
bryan34w
12
Sep 30, 2015 02:50 PM
BimmerSage
Sep 17, 2015 11:48 PM
Tacoma1313
Sep 8, 2015 01:27 PM
