One 12oz 134a can, and the pressure is high?
Old Jun 7, 2007 | 02:52 PM
Lifelongtoy's Avatar
Exclamation One 12oz 134a can, and the pressure is high?
What would cause this? And it's blowin warm.
Old Jun 7, 2007 | 03:18 PM
paxil4x4's Avatar
Drama Queen/Banned
Has the system be drawn down to a negative vacuum before charging.
Old Jun 7, 2007 | 03:26 PM
ChickenLover's Avatar
You really need to get yourself a set of a/c manifold gauges. Without them, you are flying blind. I don't know if the a/c system on your 22re is similar to that on my 3vze. But I can tell you that the refrigerant capacity of my a/c system is 23.2-26.7 oz.
I can see how adding 12 oz could easily put you above the specs. But until you get pressure readings, you won't know anything.
Old Jun 7, 2007 | 06:42 PM
yea, iv got gauges. Thats how I know its high. It sits at about 70psi while running. I was guessing a clog. Actually I think my accumulator is full. The system has been open for about a year, thats a lot of moisture. So Im gonna swap that for a new one, evacuate and re-cahrge.
Old Jun 7, 2007 | 06:53 PM
Your low pressure side is at 70? What pressure is your high side holding?
Old Jun 8, 2007 | 09:29 AM
ssupercoolss's Avatar
with the a/c running, you might get the high side up past 250 lbs, depending on ambient temp. 70 sounds like a static pressure reading. if you have 70 on the high side while the compressor is running, either you are low on freon, or your compressor aint making no pressure.
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
dumpster84
Apr 30, 2016 06:03 AM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
94ofCanada
Aug 14, 2015 06:37 AM
calderp
Jul 27, 2015 09:58 AM
