One 12oz 134a can, and the pressure is high?
You really need to get yourself a set of a/c manifold gauges. Without them, you are flying blind. I don't know if the a/c system on your 22re is similar to that on my 3vze. But I can tell you that the refrigerant capacity of my a/c system is 23.2-26.7 oz.
I can see how adding 12 oz could easily put you above the specs. But until you get pressure readings, you won't know anything.
yea, iv got gauges. Thats how I know its high. It sits at about 70psi while running. I was guessing a clog. Actually I think my accumulator is full. The system has been open for about a year, thats a lot of moisture. So Im gonna swap that for a new one, evacuate and re-cahrge.
with the a/c running, you might get the high side up past 250 lbs, depending on ambient temp. 70 sounds like a static pressure reading. if you have 70 on the high side while the compressor is running, either you are low on freon, or your compressor aint making no pressure.
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
94ofCanada
Aug 14, 2015 06:37 AM
