e-brake
Old Jun 14, 2007 | 01:41 PM
Jay351's Avatar
e-brake
okay, onto my next project.
My e-brake snapped off my handle awhile back, im tired of not having it..
I heard that our e-brakes are two peice cables, so I could just replace the front section and be done with it..
Search yeilded no results...
thanks for the help.
Old Jun 14, 2007 | 01:58 PM
Azusacanyonbogger's Avatar
first be sure of which cable snapped. if its the front i just bought one from Rockauto.com for 37 bucks shipped
Old Jun 14, 2007 | 02:01 PM
Jay351's Avatar
yes its the front, it snapped off the e-brake handle.
Woo, I thought it was going to be over 100 bucks
Old Jun 14, 2007 | 02:16 PM
dealer is like 60 bucks. that is the cheapest i've found. and i called the usual auto parts stores and they dont even carry it! i found that one just browsing online pretty good price though and shipped!
Old Jun 14, 2007 | 05:56 PM
leebee's Avatar
unless you have at least a 1" bl, there is not much room between the top of the bellhousing and the firewall to get your hands in there to get at a clip that holds the cable in place.
oh, there is a little pall (sp) above and right behind the dash that you have to reach up blindly and depress to release the cable from the handle. haynes or chiltons covers it well enough. someone may post up the 93 fsm section for you to check out.
lee
Old Jun 14, 2007 | 06:08 PM
Jay351's Avatar
ugh, this sounds like its gonna be a bitch.
I think I lost that little clip too..
Old Jun 15, 2007 | 10:47 AM
it is a bitch once you get to the part under the dash (well mine is also a bitch because i have mud caked on the bottom of my truck so i ended up with a huge dirt pile on my driveway!)....... you have to pop out that stupid pin from the lever so you can turn it enough to get the old cable out. and damn there isnt a lot of room to work with in there! but its worth it to have a brake again. tired of putting it in gear when i park. good luck!!
Old Jun 15, 2007 | 10:53 AM
dijlop's Avatar
i feel ya on putting it in gear to park. thats what my parents do regardless. drives me crazy. i start it up, BAM STALL. ugh.
kinda a quick debo high jack here, if the e-brake is a little worn out and uve basically gotta pull it all the way out to get it to stick, would it require replacing cables or whatnot to get it to tighten up a little bit?
Old Jun 15, 2007 | 11:00 AM
Jay351's Avatar
Well I went and priced out a handbrake and its dealer only.
And I refuse to give my local dealer any buisness..
Looks like im gonna try online!
oh and I dont have to worry about getting the old brake off the handle.. it snapped right off and is hanging under the truck..
Hey
Azusacanyonbogger
where did you find your e-brake cable?
only one I found online was for a std cab..
Old Jun 15, 2007 | 11:02 AM
91muddog's Avatar
thats exactly what mines doing, any have any info on adjusting the parking barke?
do the drums need to be removed?
thats not fun....
Old Jun 18, 2007 | 09:43 AM
Hey
Azusacanyonbogger
Rockauto.com
Old Jun 18, 2007 | 09:46 AM
DeathCougar's Avatar
I bought my cable from the dealer. Cheap, and correct with the correct protective rubber piece, and the clips I needed. It can be a PITA to snake the cable around the trans tunnel, but if you have a MT and a friend to help, its actually quite easy.
btw try Strap22 on here. He can get em cheap for ya.
Old Jun 18, 2007 | 10:03 AM
Jay351's Avatar
rockauto.com only has the front cable for a reg cab pickup.
I will send strap22 a pm.
thanks guys
Old Jun 18, 2007 | 10:07 AM
drew303's Avatar
My broke at the back of the handle to, freyed and snapped. I bought a cable online but it was for the 2wd (they are different!)..
So I just went to the dealer and picked one up for around $60 i think.
I just unscrewed the hand brake and got the old end of the cable out and didnt have much trouble getting hte new one in and screwed it all back in place.
All n all it was a easy fix.
Old Jun 18, 2007 | 11:12 AM
thanks guys
thats where i got mine (rockauto) and its in a 4x4 xtra cab. just installed it over the weekend. do a search at rockauto by part #DORMAN Part # C138653
Old Jun 18, 2007 | 11:24 AM
keithguts's Avatar
This may sound very strange to you all, but I never, and probley never will use my e. Brake. I hate them. Had one stick in me one time, and it runed my brakes. Never used it since. Aprox 30 years. Strange right...........
Old Jun 19, 2007 | 05:58 AM
randlejam's Avatar
I have recently purchased a 89 4runner, and when I got it relized the e-brake was broke. The truck has a 6 inch lift so I may just need to extend the cables. ANYONE HAVE ADVICE?
Old Jun 19, 2007 | 07:17 AM
8yota9's Avatar
as bad as i wana fix mine.. its the front cable.. i just cant see spending 60 bones on a pice of wire. o and is bump starting bad for your truck
Old Jun 19, 2007 | 08:21 AM
razrwild's Avatar
What about taking off the old cable and going to a bicycle shop to see if they have a cable that's similar? Or if we have some parts guys around checking it against another vehicle brake cable length?
