Anyone installed a center support bearing?
Old Jun 12, 2007 | 05:36 AM
BC Rider's Avatar
I recently changed out the center support bearing on my truck. It was pretty simple, but on reinstalling the driveshaft I found that I had to push the flange around the bearing toward the back of the truck to get it aligned with the holes in the bracket on the frame. The rubber flexes enough to accomodate this (about 0.5 inches).
So basically the bearing now pushes towards the front half of the driveshaft.
Anyone know if this is OK or should I redrill the mounting holes to remove this "pretension"?
And yes - I have the bearing flange cutouts facing to the back of the truck which according to the fsm is correct.
Thanks in advance for any information.
Old Jun 12, 2007 | 06:04 AM
DaveInDenver's Avatar
I'd have said you have it backwards, but sounds like you have that covered. Mine lined up just fine, no problems. Is the part OEM or aftermarket?
Old Jun 12, 2007 | 05:42 PM
BC Rider's Avatar
Thanks for the reply - I must have something snafued. I'll recheck it.
Mine is OEM.
Old Jun 12, 2007 | 05:45 PM
Bigblock's Avatar
The rubber wore out in mine but not the bearing,so it never got replaced.
bigjstang
Jun 2, 2025 03:56 PM
glowz825
Jan 25, 2022 09:28 AM
jerusry
Oct 19, 2015 05:28 PM
Sep 4, 2015 09:27 AM
terminator
Jul 27, 2015 07:13 PM
