Different trannys that will bolt behind the 3vz
Old Jun 10, 2007 | 10:25 AM
shoes138's Avatar
My question is, is there any other trannys that you can bolt up right behind the 3vz-e motor. Such as the 5vz tranny. cuz i doubt that my stock tranny will be able to keep up with my new motor. also im gettin my pistons n connecting rods forged by Weazy but UPS said they lost the docs. and waiting for sumthin, has this happened to any of you guys?
Old Jun 10, 2007 | 10:50 AM
SR5's Avatar
SR5
well whatever new motor you getting use that trany to bolt behind your new motor
Old Jun 10, 2007 | 10:54 AM
DeathCougar's Avatar
The R-151F will bolt up behind it, provided you have the 3VZ bell housing. Its a turbo trans, very stout, with a 23 spline output shaft for the GEARDRIVE tcase.
5VZ trannys have a drivers side drop for the diff in the t-case, so that will not work (unless you can find one from a 96-97 T100, which was a 5VZ pass side drop)
Old Jun 10, 2007 | 11:14 AM
shoes138's Avatar
now i deciding either to swap a manual tranny or keep an automatic tranny. i believe the R-151F is a manual tranny right?
Old Jun 10, 2007 | 11:34 AM
95RunnerSR5's Avatar
yes its a manual.. you will need one out of a 2wd of course. one from the newer 4runners and taco's with the 3.4 will work just make sure its 2wd
Old Jun 10, 2007 | 11:52 AM
doh didn't even think about 2wd lol. If you have 2WD, then obviously the Tcase problem will not be an issue. However, the 5VZ input shaft IS longer than the 3VZ, so i dont know about that one.
Old Jun 10, 2007 | 01:04 PM
Stomis's Avatar
Hmmm for some reason I dont think you can build a 3.0 with enough power that the stock tranny cant hold it. People put that tranny behind v8s all the time.
Old Jun 10, 2007 | 04:17 PM
tc's Avatar
tc
x2 The exact same tranny is behind the 5VZFE (with a different bellhousing) and is holding up to them just fine.
Turbo trannies (R151F) are hard to find and expensive. V6 trannies (R150H) are a dime a dozen...
Old Jun 10, 2007 | 06:00 PM
Stomis's Avatar
Lol I've seen them behind 350 and seen one behind a 305 in person. The kid drove it like it was a race car and never broke anything.
Old Jun 10, 2007 | 06:29 PM
x2 i have seen 3.4's supercharged with the 3.0 trans
Old Jun 10, 2007 | 06:43 PM
JamesD's Avatar
The best combo would be a R154 trans out of a MK 3 Supra and a bellhousing out of a 5vz truck. Since the R154 has the same length input shaft and the 96 and up Taco V6 R trans. Since you are 2wd the Supra trans would give you an overall better ratio.
James
Old Jun 11, 2007 | 12:54 AM
shoes138's Avatar
yea but i dont have a manual, i have an auto. i no the manual can take the punishment of the 5vz-fe i dunno how much punishment the autotrannys can take
Old Jun 11, 2007 | 05:00 AM
bigtrucknwheels's Avatar
the auto will not work with the 5vzfe. even though they have similar transmission codes, they are not the same. the only transmissions that would work in that swap is the manual from the 3vze or the Original automatic bolted fast to the donor motor or a manual coupled to the 5vzfe.
i dont know about the compatibility of other manuals, but the auto has to be the same one that was bolted to the block. sure other ones will fit, but they all vary a little bit and the ECU will only work with its original auto tranny.
Old Jun 11, 2007 | 07:54 AM
shoes138's Avatar
well i guess when i put my new motor in we will see how much punishment my auto tranny can take. i want to go manual, but it seems like alot of work to put it in. i dunno i gotta get the motor done first. thanks guys
Old Jun 11, 2007 | 08:18 AM
Jay351's Avatar
If you putting in a new engine then you can do your 5sp swap
Nothing feels better then going through the gears
Old Jun 11, 2007 | 08:29 AM
shoes138's Avatar
yea i kno, i wish my yota had 5spd in it right now. but i guess it will do for right now.
pplusent
Sep 18, 2018 10:02 PM
squiggypowell
Aug 19, 2015 03:07 PM
agrout
Aug 13, 2015 06:12 PM
yourrealdad
Jul 21, 2015 11:13 AM
Iceman4193
Jul 15, 2015 04:48 PM
