PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 [159] 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. FORGED PISTONS and KNOCK SENSORS
  2. pitman arm question
  3. Loud grumble on cold startup. Thermostat?
  4. Home built cold air intake
  5. Rough idle when warm
  6. Haunted emergency brake
  7. Bad ECU?
  8. 4runner Brake Valve raise bracket
  9. 3vze gaskets and oil pump replacment
  10. Removing tailgate lock cylinder
  11. '94 4Runner Auto Trans
  12. Bigger fuel tank/Auxiliary tank options
  13. How to make an awesome cradle for your phone/mp3 player
  14. 88 4runner 3vze. Idles fine when cold but not at operating temp.
  15. Valve Body and o2 Sensor
  16. 1995 4Runner Questions
  17. 87 turbo rebuild kit
  18. Rear main seal question, yea i searched
  19. engine performance
  20. Rear Window Tint Removal
  21. 92 shortbed- you can have the bed!
  22. Fuel Filter in tank?
  23. '95 4runner V6 Major Oil Leak
  24. 91 3vze 4runner won't start
  25. frame patching question
  26. Parts in GTA, Ontario
  27. Post Up The 2nd Gen Pickups!!!
  28. 3vze Dipstick Tube leak
  29. 88 4runner rear window inside weatherstrip
  30. My new 3.0L Turbo DIESEL...........
  31. 3VZ-E bolts for engine stand
  32. New 95 4runner - Stressed.. Need advice
  33. ToyTec Interchangable?
  34. Wreck my beloved 88 yota.. Pics
  35. Real quick... 85 buckets into 92 truck?
  36. AC 134a conversion
  37. charge light problem
  38. Yota 4runner listed as 5th vehicle to "last 4ever"...
  39. Seattle smoke-type vacuum leak detector?
  40. sway bar disconnects
  41. Starting Issues
  42. 94 in a 92 AC Suction line queston :)
  43. gear shift knob removal
  44. a/c in 87 4runner
  45. transmission Fix lube
  46. new cap+rotor+boost timing=nice
  47. Transmission top plate ???
  48. leaking coolant
  49. Throttle body, IACV and a busted t-case (picture)
  50. 88 yota... V6 or 22RE
  51. Starting modifications on m 93 4runner?
  52. Give me a list of what could cause my squeak!
  53. Push-started...now dash lights won't work!
  54. Cold air intakes...anyone using em?
  55. Paint chrome bumpers?
  56. Just Died
  57. My starter wont turn
  58. Clutch questions 95 4 runner from a newby
  59. Drove over a ledge - Sudden, Extremely Loud, Engine Tapping (& timing parts question)
  60. cooling system corrosion
  61. replaced oil cooler seals today
  62. 93 4-Runner fuel pump change out
  63. Getting seats redone
  64. installed clutch in neutral
  65. 3.0 code 51 help
  66. 22r carb
  67. 86 22r Misses/Stumbles After an Hour of Highway Driving
  68. would 95 runr rear seat fit 1st gen runner?
  69. what do you think about my unsettled shackle angles, TG 3"
  70. Stock Cam specs
  71. Newb question about the 22re
  72. 4runner gas tank notch?
  73. And so the 22re rebuild begins
  74. tailgate wont open
  75. '90 pickup 3.0 failed smog...
  76. Swap for slidnig rear window 91 pickup
  77. 93 Parking brake
  78. Filling up a forward shift t-case through the shifter?
  79. Window Relay
  80. 89-95 Rear Truck bumper on 90-95 4runner?
  81. 87 22ret Timing Chain
  82. The 4runner tailgate, tear down and build
  83. code light and fixes?
  84. 4.88's with 235/85r16's??
  85. Want to add A/C
  86. bolt at end of axle after snap ring???
  87. anyone rebuiled a steering box
  88. 22re 5 sp tranny slipping out of gear
  89. Engine rough idle
  90. A/C Help Please 89 Pickup
  91. This + That+ These = Bad as* 22re I hope
  92. CV joint relacment
  93. transfer case leaking, it figures
  94. IFS suspension questions
  95. 2wd Bed vs 4wd Bed question
  96. '94 4-Runner Wheel Squeaking/Chirping?
  97. '93 toyota pickup clutch lines
  98. '91 3.0 4WD CE light and bogs
  99. surging rpm's, cuts in and out while driving.
  100. Im looking for idler arm/ IFS upgrades
  101. Clutch Soft Line
  102. 4 Runner died in Mountains today!! Please Help me diagnose
  103. 93 4runner (alt,battery causing tranny noise?)
  104. What shocks for IFS lift... gas?
  105. Aftermarket clutch line?
  106. intake manifold stuck to head 3VZ-E engine
  107. 4runner rear alignment
  108. 1st gen 4runner seat rail swap (already searched).
  109. Rear coil spacers with downey coils?
  110. Pics after a nice wash and wax...PIC HEAVY
  111. Will a 3rd from a 2000 tacoma fit my 1995 4runner
  112. Speaker Replacement
  113. Head gasket issues AGAIN, Advice and input needed..READ ME!!!..
  114. 1991 toyota pickup tranny problem
  115. 2WD Pickup
  116. Pulled the carpet, anyone need it?
  117. 93 v6 5 speed issues... rebuild?
  118. Thinking about going SAS need your input
  119. Piggyback fuel controller on 3vze
  120. 1991 4Runner New to Me
  121. 22re flooding on warm start
  122. 90 3.0 no start..help...
  123. Manti Utah offroad show Pics
  124. Rebuild or Replace?
  125. Want to put a snorkel on my pickup
  126. removed some leafs
  127. Flywheel question
  128. FUEL PUMP HELP.....Yes hHave read many post already..
  129. How do I stop chain guard leak
  130. Rear pinion seal
  131. 3vze - I can't get it to overheat
  132. Replacing CV joints, DIY or no?
  133. 3VZE Timing Redo
  134. Won't shift into gear.
  135. 4WD Selector rattling, bad bushings?
  136. help, slave cylinder!
  137. 94 4runner 3.0 cold/warm start issue
  138. 94 4runner 3.0 cold/warm start issue
  139. Bumpstop rusted off, trapped in coil spring...help (pic)
  140. Leaking coolant - In the red!
  141. Body lift shifter extension
  142. Quick Cig Lighter Question
  143. Die Hard Platinum retrofit into a 2nd Gen Runner
  144. Help putting tranny back in
  145. fender liners
  146. truck tailgate on a 1st gen 4Runner?
  147. bikini top installed, pics.
  148. 2WD compared to 4WD Pitman Arms
  149. Knock sensor
  150. Bad gasoline?
  151. Best Exhaust system for 93 22RE 4x4
  152. W56 trans Bearings????
  153. 5.29's are to low for 35's
  154. ca forestry service roads?
  155. bye bye cat :(
  156. Spectre filter box, possible snorkle use?
  157. Front End Madness
  158. Where to buy bumper?
  159. 89 recall
  160. pitman arm help
  161. BJ spacers, cruiser coils, stock shocks?
  162. Torsion bars...
  163. Brake caliper shim?
  164. CEL but no codes!
  165. weird trans issue maybe?
  166. A couple of pics from today! Also how to lower fj80 coils???
  167. Taco 16" wheels for CHEAP...
  168. removing inner A-pillar panel
  169. alternative to clutch pedal
  170. Wheel fell off @ 70mph!
  171. show me your pics of lifted 1986 to 1988 pickups
  172. gave my motor an checkup
  173. Just finished headgasket need help
  174. torsion bars half moon spacers
  175. Factory Tow Package
  176. straight wiring the fuel pump just for testing 22re
  177. blue 22re block?
  178. Might need an ECM? Injectors not firing. Need help!
  179. any pics of 2nd gen 4runners with 37s?
  180. weird vibrations?!?!?
  181. 3VZE need's a metal head gasket who's going to help
  182. Nearly new chain making noise.
  183. i got code 71 its egr code
  184. Shocks DT3000's and DT9000's
  185. Best ring and pinion?
  186. A340H no upshift to 3rd and freewheels in OD
  187. v6 engine bracket
  188. Gone like a freight train...
  189. Hood insulation? Is it needed?
  190. RV6 Idling High
  191. auto hubs to manual.
  192. Pre Filter for 3.0 K&N intake?
  193. Brake caliper line part number
  194. I have a bad tranni my reverse slips out of gear
  195. steering problem
  196. Erratic speedo and other warning lights
  197. 1989 4runner running extremely rich!!
  198. 3vze Vacuum Lines and Fuel Return? right side of engine
  199. How do I lower my 2WD?
  200. Code 12 HELP!!!!!!!!!!!!
  201. air compressor and power steering brackets
  202. 3.0 staggering
  203. Rear axle width's on ifs trucks
  204. 92 coil to 88 distributor cord
  205. doesn't even shift out of park
  206. Transmission interchange
  207. Has anyone else had this problem with their 22RE
  208. Rear discs.
  209. Rusted rear brake line, problem and what I did to fix...
  210. toyota differental code help
  211. Differentials, what to do?
  212. Shift linkage adjustment or replacement?
  213. Rusted frame worth fixing ??
  214. Get these taillights?
  215. power steering bolts
  216. running hot!!!!
  217. Rough idle on startup
  218. Bikini top on the way!!!!!!
  219. so I asked the 95-200 tacoma forum, but now im asking you
  220. what size wrench do I need to take the rear shaft loose from the rear end.
  221. 3.4l Engine/Tranny Transplant into 3rd Gen Toyota Pickup
  222. Random auto trany!
  223. high steer pics
  224. lower control arm is driving me crazy
  225. Ignitor wire connector problem
  226. 3vze, code 52, knock sensor
  227. Steering Box Tech
  228. check your belts!!!
  229. Shift Solenoid Question
  230. 5w-30 in 3vz?
  231. 22re acting weird
  232. Calling All Carb Gurus!
  233. Power steering fluid......
  234. In need of some help with my engine
  235. lost nut
  236. removing 89 truck fenders
  237. 95 Rod Bearing & Head Gasket replacements
  238. ordered a body lift!!
  239. 300k 3vze 4runner!(pictures)
  240. Chevy alternator in a 88 4runner
  241. baja style light bar
  242. Need an assist in New Brunswick!
  243. 4Runner is officaly dead.
  244. T1-E1 jumper help!!!
  245. thinking about regearing need advice!!
  246. 91 4Runner valve noise?
  247. 15 degrees advanced?
  248. help with tb and tps
  249. Rear door speakers? 1991 4Runner 4-door
  250. Size bolt fits in top rollbar hole of 4runner?
