93 v6 5 speed issues... rebuild?
Old Jun 21, 2009 | 06:47 AM
mario65's Avatar
Its slips out of first, wont downshift into 3rd. what would you do? Whats the tranny model number?
thanks
Old Jun 21, 2009 | 07:42 AM
[N8]'s Avatar
I would look for a part out or used tranny for sale. Should be able to get 1 for under $200. Your tranny should be a R150F.
Old Jun 21, 2009 | 09:35 AM
pitster33's Avatar
mine was popping out of first and would always grind going into reverse. I threw a marlin crawler shifter seat and the ball that goes on the end of the shifter on it and now its tight and shifts better than any of the 10-15 yota's I've driven.
Old Jun 21, 2009 | 11:33 PM
TNRabbit's Avatar
^^^^Try this first. Also check for a cracked clutch pedal bracket if you're having trouble getting INTO gears.
Old Jun 21, 2009 | 11:43 PM
Jay351's Avatar
Try the er seat and bushing (a must do for any r150 trans) from marlin crawler. Then check for cracks in the clutch pedal bracket like Tn mentioned.
If its still problimatic, then look for a used trans. You can get them for under $250 with a transfercase. 89-95 is all the same with the exception of the electric/cable speedo.
Old Jun 22, 2009 | 01:46 AM
mario65's Avatar
thanks everybody. Ill get the bushing first. It is sloppy.
Which color bushing for my tranny?
By the way if I do get a tranny what years of the r150f have the same speedo connections?
Old Jun 22, 2009 | 03:51 AM
TNRabbit's Avatar
If you get a replacement tranny, talk to MarlinCrawler; their rebuilt trannys are great.
bigjstang
Jun 2, 2025 03:56 PM
young buck
18
Aug 27, 2018 02:40 PM
shadowbirdie
Jul 21, 2015 10:38 PM
wilbertd
Jul 6, 2015 07:39 AM
karbin
Jul 5, 2015 11:37 PM
