installed clutch in neutral
Old Jun 23, 2009 | 02:25 PM
wbthornton88's Avatar
Ok, I hope I didn't mess up. i installed the clutch in neutral today and I used the alignment tool. When braking the bolts around the pressure plate loose, the entire flywheel turned with me. When I tightened the bolt's the flywheel also turned. Will this cause a problem when lining the tranny back up?
Old Jun 23, 2009 | 02:33 PM
Jay351's Avatar
It shouldnt be. You might have a little touble lining the splines up but nothing can be damaged..
Old Jun 23, 2009 | 02:38 PM
iamsuperbleeder's Avatar
yeah your fine
when you go to line the trans back up, just put it in 1st gear, and wiggle the drive shaft as your mating the trans to the motor, and everything should lock in fine
Old Jun 23, 2009 | 02:40 PM
k thx peeps
Old Jun 23, 2009 | 03:29 PM
TOYOTA 1's Avatar
how could you install a clutch in gear?
Old Jun 23, 2009 | 04:10 PM
eric-the-red's Avatar
Exactly. With the gear box removed neutral and in gear don't really apply.
As long as the flywheel bolts are torqued correctly it'll be fine.
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
PlayAwhile
Jul 20, 2015 11:36 AM
1996Taco
Jul 20, 2015 12:02 AM
