i got code 71 its egr code
Old Jun 17, 2009 | 09:29 AM
Countryhick's Avatar
how should i approach it.
Old Jun 17, 2009 | 09:54 AM
desertcamper67's Avatar
Check to see if the diaphram is working. You can see/feel it move with vaccuum applied. Also the lower port on mine was severely clogged. I had to take it off and run a wire and carb cleaner throuh it. It finally opened up to the big pipe.
Finally the EGR module needed to be changed on mine. Its a dealer item and not expensive. This is what I had to do to pass smog anyways. My truck codes don't go nearly that high. Up to code 12 or something like that.
Good luck
Old Jun 17, 2009 | 10:31 AM
TNRabbit's Avatar
Approach it quietly from behind & jump on it quickly with both feet...
Old Jun 17, 2009 | 09:39 PM
Keith B.'s Avatar
Mine's doing the same thing now, intermittent, for a few months. I pull the EFI fuse momentarily(truck stopped) to clear it. When it stays on all the time, I'll investigate. EGR valve is in a lousy place...very difficult/impossible to see to service.
splangeland
Apr 6, 2024 08:14 PM
some drunk guy
Aug 3, 2021 06:09 PM
accuracy
Sep 20, 2015 07:44 PM
jmoua
Sep 15, 2015 12:44 PM
Boomer8404
Sep 10, 2015 09:01 AM
