5w-30 in 3vz?
Old Jun 15, 2009 | 08:15 AM
bigredscowboy's Avatar
5w-30 in 3vz?
I have some 5w-30 left over and wondering if I can use it in the 3.0L?
Old Jun 15, 2009 | 08:37 AM
Jay351's Avatar
You can... its a little thin though. I wouldn't bother, just run 10w-30
Old Jun 15, 2009 | 08:38 AM
Godzilla's Avatar
Typically 5W30 is the recommended grade.
Old Jun 15, 2009 | 08:42 AM
Jay351's Avatar
Yeah, if its a newer motor
Old Jun 15, 2009 | 08:45 AM
Godzilla's Avatar
Well the 5W to 10W is not going to make a difference after startup, so it really shouldnt matter.
Old Jun 15, 2009 | 09:30 AM
fdp101452's Avatar
been running 5-30 for a long time and no problems....regards.....Rick
Old Jun 15, 2009 | 09:34 AM
Tubbyfatty's Avatar
If its hot where you live, 80s or higher, you should run 10 40, it wont burn as much.
But yea, 5 30 is a bit thin.
Old Jun 15, 2009 | 01:18 PM
space-junk's Avatar
i follow the owners manual and it says 10W-30... so thats what i use...
Old Jun 15, 2009 | 01:22 PM
Team420's Avatar
5w30 in winter, 10w30/40 in summer
Old Jun 15, 2009 | 03:27 PM
dutchboy's Avatar
Agreed :>)
Old Jun 15, 2009 | 04:15 PM
KVRunner's Avatar
My 4runner has had 5w 30 put in it since it was new. It now has 167,000 miles on it.
Old Jun 15, 2009 | 11:25 PM
abecedarian's Avatar
5w30 may be a bit thin for warmer weather vehicles. If it works fine, no abnormal knocking noises, etc. and oil pressure is within normal parameters, then it shouldn't cause any issues. However, if you're not getting below freezing, you might consider a 10w30 if you can find it, or a 10w40, particularly if most of your driving is cruising on the highway.
Just my opinion though.
matmattmatthew
10
Feb 9, 2021 04:15 PM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
D.B.T. 87 4x4
Jul 20, 2015 04:51 PM
