intake manifold stuck to head 3VZ-E engine
Old Jun 21, 2009 | 03:52 PM
livinitupinthemud's Avatar
i just bought my 89 runner. everything was all good until i needed to replace an exhaust valve and replace my gaskets. i've got all the bolts off that were holding it in(unless there is one hiding somewhere but i can not find it). it moved off the front two and the back left, but its stuck on one bolt. does anyone have any thoughts on how to get it off? any ideas are appreciated
Old Jun 21, 2009 | 05:40 PM
DJ99's Avatar
There are 4 bolts down the middle of the intake, front to back, and two deep on either side of the throttle body. If you get all 6 off, the intake will come off.
Old Jun 21, 2009 | 11:28 PM
TNRabbit's Avatar
Pop it with a rubber hammer if you've got all 6 bolts out; it should break loose. BE VERY CAREFUL TO REMOVE THE VACUUM HOSE GOING TO THE PLASTIC "TIT" IN THE BACK OR YOU'LL BREAK IT OFF!
Old Jun 22, 2009 | 08:52 AM
DeathCougar's Avatar
Check and double check that you got all the bolts out. 6 doesn't sound right.
You also need to make sure all your hoses, and wiring is disconnected. Those things can be a maze to remove
Old Jun 22, 2009 | 09:26 AM
DupermanDave's Avatar
It's hammer time!!!
Old Jun 22, 2009 | 11:33 AM
i have the top of the manifold peeled back and off to the side
and there are 14 or 16 bolts that hold the bottom of the intake onto the heads, there are 4 leader bolts that go from the head up through the intake to guide it on, this is where the problem is, front two and back left guide bolts are loose but the last one is a rotten little........i'm doing all this with the engine in so accessibilty isn't exactly the easiest
bigjstang
Jun 2, 2025 03:56 PM
Colington
Mar 8, 2020 09:51 AM
steve miller
Oct 10, 2015 01:40 AM
87blyota
Jul 10, 2015 04:31 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
