4 Runner died in Mountains today!! Please Help me diagnose
Old Jun 21, 2009 | 07:04 PM
simpsons721's Avatar
Unhappy 4 Runner died in Mountains today!! Please Help me diagnose
My runner died going up the mountains in colorado today
all i wanna know is does it sound like my head gaskets are blown
what i can say is i was driving and my car stalled out
tried to start it and it just sounded like it was getting no gas
(wouldnt turn over)
There was a burnt smell like something was overheating also
i really dont want to hear my HGs are blown i replaced them 3-4 years ago
give me your honest opinion
if you need more info reply with what you need to know
right now the runner is at a stealership just because it may have to be traded in, its been through a lot. They will diagnose it tommorow
Old Jun 21, 2009 | 07:10 PM
Tubbyfatty's Avatar
Need more info.
you say it wont turn over as in crank? Was the temp gauge in the red? Was there any smoke?
Old Jun 21, 2009 | 07:13 PM
abecedarian's Avatar
timing belt?
Old Jun 21, 2009 | 07:16 PM
yes the engine does not crank
temp gauge was normal - but ive been meaning to replace this for a year becuase the radiator does usually feel hot, so gauge may be broke but it reads in the middle
and no smoke anywhere- which i did feel good about
Old Jun 21, 2009 | 07:19 PM
hopefully timing be;t
what are symptoms of blown head gasket
Old Jun 21, 2009 | 07:20 PM
tc's Avatar
tc
Mine would get vapor lock type symptoms - would die on the pass, let it sit for a little while and it would start right up.
Turned out to be a heat-soaked ignitor.
Old Jun 21, 2009 | 07:23 PM
Tubbyfatty's Avatar
On top of smoke coming out of the exhaust, chocolate milk like oil, coolent is brown from oil. um...yea.
Old Jun 21, 2009 | 07:24 PM
thanks for the input tc
Old Jun 21, 2009 | 07:26 PM
coolant is still green
also i did have a pretty bad power steering leak, could it have screwed up something
Old Jun 21, 2009 | 07:29 PM
tc's Avatar
tc
If the headgasket blew enough to stop running, there would be other symptoms - dramatic overheating, smoke, etc.
Timing belt would do what you describe.
Hope for you it's the ignitor!
Old Jun 21, 2009 | 07:35 PM
tc up in longmont thank you
i know when my hg was bad last time there was dramatic overheating signs
and i have never replaced my timing belt since getting the runner with 80,000 on it
Old Jun 21, 2009 | 07:41 PM
tc's Avatar
tc
Did it get weak, sputter, come back, sputter, die
(if so, ignitor)
just flat out quit like right NOW?
(if so, timing belt)
Old Jun 21, 2009 | 07:59 PM
flat out quitted
it was exactly like when i ran out of gas driving down a hill and then the enigine wasnt running, my battery light came on and my brakes pretty much werent working
Old Jun 21, 2009 | 08:59 PM
any other opinions?
Old Jun 21, 2009 | 10:38 PM
874runnersr5's Avatar
pull the codes?
Old Jun 21, 2009 | 10:51 PM
nv4runner's Avatar
The 3.0 is a non-interference engine, so a broken timing belt would result in the engine cranking over real easy. The burnt smell might have been your starter if you tried to crank it and it wouldn't turn.
Old Jun 22, 2009 | 05:33 AM
ScottyC's Avatar
Could have been timing belt.
What makes me wonder is the burnt smell. Was it an electrical burnt smell? If so, it could have been a short that basically fried an alternator wire or ignition wire. Were you getting power to the normal spots?
Old Jun 22, 2009 | 08:08 PM
toyota diagnosed it today and fixed it, part cost 1.07 an efi fuse
but diagnostic ran it to 100 bucks
also they said i need to replace the following because im sure this stuff is past due for a repair
valve cover gaskets, idler arm, power steering pump reseal, timing belts and drive belts
im gonna handle all that other junk 1 day maybe soon maybe not
my whip is 2wd i live in colorado and want to be in snow with 4wd so im not in a hurry
kinda feel dumb about the fuse but ive had bad experience breaking down when it was my HGs blown before
but i have had a lot of good experiences with my 2wd runner chugin to the mountains
how urgent should i fix some of that stuff alot of it looks pita
Old Jun 22, 2009 | 08:20 PM
Tubbyfatty's Avatar
you can do everything by yourself.
As far as easy, the belts and idler are easy. The idler is 3 bolts (i think 17mm) and a joint and its out.
The belts are a pain but its easy, i still need to do mine but im lazy and dont drive.
And its timing belt, not belts haha. It probably have toyota do that. Its not hard, it just takes some time.
Are your valve covers leaking? if not, i dont see why they need to replace em.
Old Jun 22, 2009 | 08:29 PM
valve cover is leaking
and what i meant by belts it the 3 drive belts are worn down
but i also was talking about my timing belt
i do sound dumb when talking about my runner because im pretty big noob but i have learned a lot from all my time reading this great site
