Clutch Soft Line
Old Jun 21, 2009 | 07:15 PM
jd20phill's Avatar
Clutch Soft Line
The clutch soft line that runs from the hard line near the firewall to the hard line that runs in the direction of the slave cylinder sprung a massive leak today and left me without a clutch. Anyways, It is now stranded at my job and need a fix quick. None of the auto parts stores around here seem to carry it and i need to get this fixed tomorrow. Is there any other Toyota clutch or brake line that will work?
Old Jun 21, 2009 | 07:18 PM
Tubbyfatty's Avatar
I think i just read a thread that said a front brake line will work just fine.
https://www.yotatech.com/forums/f116...h-line-184925/
post 5
Old Jun 22, 2009 | 10:42 AM
jd20phill's Avatar
Follow Up
Alright, the front brake line for the 90-95 4runner does work! It is 14 inches long instead of 11, but it will still fit in the bracket (cost 12 dollars from napa, instead of the 40 Toyota wanted for the clutch line). Be sure to get a 10mm flare nut wrench to remove the hard lines (no chance of rounding it off and it doesn't slip off). And remember, there is an access panel in the wheel well (makes getting the line out of the bottom bracket so much easier. Have fun bleeding the clutch after this.
Thanks for the help
Old Jun 22, 2009 | 10:57 AM
881stGenRunner's Avatar
nice man glad to hear it went well. My clutch line was hitting my manifold and burned a hole in it and left without a clutch 1 hour from home. When I got home, we took some steel braided brake line too. Glad to hear it worked out fo ya.
Old Jun 22, 2009 | 11:06 AM
dem0nk1d's Avatar
worse comes to worse start the truck up in first gear with the pedal floored. then pop it out of gear and let the engine rev over 4000 RPMS, and on the drop from 4000RPMS to 1000RPMs apply pressure into the next gear. It works like a champ down shifting is harder.
Old Jun 22, 2009 | 11:52 AM
Nashman00's Avatar
i re did my as well poile oh crap factory rooting is gone replace wiht steel braid as well
Old Jun 22, 2009 | 12:44 PM
jd20phill's Avatar
i would have tried to drive it without the clutch, but i might just live in one of the hilly-est places on earth with a stoplight on each incline. Everything worked out though, so no worries.
nvdesertrunner
May 11, 2020 08:18 PM
dumpster84
Apr 30, 2016 06:03 AM
Sep 4, 2015 09:27 AM
58rennur4
Aug 4, 2015 08:49 AM
Athansinis
Jul 27, 2015 08:38 AM
